Interesting setup
Old Oct 17, 2007 | 11:07 AM
drSquish's Avatar
Default Interesting setup
Will a setup like this, originally built for all motor hold boost?
B16A bored/honed .5mm over with a P+P head/built valve train
Endyn Rollerwaves at about 10.8:1
7 layer head gasket (drops the compression about one point)
Tunertoy rods
Endyn Fluidampr
Can this setup handle 300ish to the wheels daily? I'm running a Precision T3/T4 57 trim .63 A/R. I also plan to have a second boost setting on my Profec to make about 400 whp. What am I looking in terms of reliability and strength?
Old Oct 17, 2007 | 12:12 PM
DaveF's Avatar
Default Re: Interesting setup (drSquish)
its not that hard to buy a new set of pistons and rebuild the block.
Old Oct 17, 2007 | 12:15 PM
drSquish's Avatar
I plan on saving that money for a sleeved LS block. That way if this dosen't blow I'll have two. Even if it does blow I'll have a block with more displacement at a lower price.
Old Oct 17, 2007 | 04:41 PM
drSquish's Avatar
yes? no?
Old Oct 17, 2007 | 04:48 PM
melovesboost's Avatar
Never been a fan of Those Big Layer Headgaskets. always end up being junk IMO.
I dont see why 10.8:1 would be bad the New Si and RSX's have higher compression its all in the tuning man. Good Fuel + Good Tuner shouldnt be a problem
Old Oct 17, 2007 | 08:44 PM
drSquish's Avatar
so my goals are reasonable...?
Old Oct 17, 2007 | 09:05 PM
japan4racing's Avatar
imho 10.8:1 is kinda high for boost. but if you keep the boost levels down it wont be too bad with a great tune. but just know that it is not recommended that you run high compression with boost
Old Oct 17, 2007 | 09:06 PM
you can make the power you are asking about but its gonna take a tune. detonate one time and kiss it all goodbye! you on stock sleeves?
Old Oct 18, 2007 | 11:05 AM
drSquish's Avatar
yes, stock sleeves. I've been reading and some people say increase boost, not timing to get that kind of power on stock sleeves.
dc2ls-vtec
Aug 7, 2008 01:06 PM
BlownSi05
May 2, 2008 11:07 AM
integraboosted
Sep 1, 2006 06:46 AM
WH0R3nEF9
Nov 3, 2005 05:09 PM
