interesting new problem....
Old Dec 25, 2007 | 06:56 PM
civicminded311 EK's Avatar
Default interesting new problem....
ok...so let me first start off by saying this is my first turbo'd civic...i have done a few swaps and deceided to try my luck at turbo set ups...with that in mind...i have a d16 with a mild turbo build up...i blew the head gasket a few weeks back and i was stuck in a place where i didnt really have a choice of doing the work myself..so i had someone do it for me...anyhow..everything is back together now...including a set of arp studs and a honda oem head gasket as well as having the head presure checked and the valves set....so here it is ..my problem...i know i have a leak somewhere cause it isnt building any boost....but i do notice that when accelerating i hear ( what sounds to be like a engine on bad gas) any thoughs on what this cold be?...it almost sounds like a pinging noise....but only under full acceleration....
Old Dec 25, 2007 | 07:00 PM
willyboyK20's Avatar
Default Re: interesting new problem.... (civicminded311 EK)
what are you using for tuning?
Old Dec 25, 2007 | 07:13 PM
Default Re: interesting new problem.... (willyboyK20)
right now i just have a missing link on it, i know i know it needs tuned correctly...i have mad plans to get it done with a tuner near philly...he has my new injectors and my conversion hardness and a few other things..i am going to go with a neptune tune i believe.....but my concern is that i hope i didnt do any serious mechanical damage when i blew the haed gasket...it never made that sound for the 8 weeks i had it together before i blew the head gasket...
Old Dec 27, 2007 | 12:50 PM
NonovUrbizniz's Avatar
Loved
Uh... you're running lean at full throttle and the engine is detonating like a ****?
That's certainly what it sounds like.
That or you're SOOO rich due to not building boost that the fuel left over in the cylinder is detonating in a non-combustion stroke...
Generally if you hear pinging it's not good...
Check to see if MAYBE your cam timing got set wrong when you re-installed the head.... that MIGHT cause the pinging but wouldn't really account for not building boost... but that could be as simple as a loose connection in the charge piping.
Good Luck.
Which D16? because 90pct of the D's cam timing gets set one way (align the front facing mark with the cyl. head) and the Z6 and I think maybe one other engine get set to differently (there is a tab mounted behind the cam gear where the marks need to be aligned to).
Prelude900
May 10, 2015 02:47 PM
nyte_rider
Honda Civic (2001 - 2005)
May 19, 2008 08:48 PM
Missouri_Civ
11
Aug 13, 2007 02:27 PM
boomersz
10
Apr 11, 2007 04:37 PM
konio
Jul 15, 2006 09:54 PM
