sohc needs help
Old Dec 26, 2007 | 06:55 AM
mycarslow's Avatar
Default sohc needs help
ok went to install my dsm 450s today in a 97 civic with the y7 do i need to sawp over to the obo1 injecotor plug ins? or do you shave it donw the ones i have and then will they work?
also here is my last ? for the day on my chiped p06 i got from jk tuning it says i need to do the 3 wire to 2 wire IACV conersion what does this mean?
Old Dec 26, 2007 | 09:01 AM
RACEPAK's Avatar
Default Re: sohc needs help (mycarslow)
for the iacv:
http://www.ff-squad.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycarslow &raquo;</TD></TR><TR><TD CLASS="quote">
Old Dec 26, 2007 | 09:37 AM
mycarslow's Avatar
Default Re: sohc needs help (RACEPAK)
any one know about the plug in on them dsm 450s as in what do i need to do to make em fit
Old Dec 26, 2007 | 10:47 AM
1991civicd16z6's Avatar
you cut the little tab thing on the inside of the dsm's and you use obd1 injector clips...
Old Dec 26, 2007 | 01:34 PM
mycarslow's Avatar
Default Re: sohc needs help (1991civicd16z6)
ok so your saying buy the obd1 and wire them in and it will fit??
Old Dec 27, 2007 | 12:26 PM
mycarslow's Avatar
bump
Old Dec 27, 2007 | 01:57 PM
Joseph Davis's Avatar
There is no 3 wire to 2 wire IACV conversion for D16Y7, not unless you swap to a non-Y7 intake manifold.
If you do not want to swap for whatever reason - maybe you like the way the Y7 IM flows like donkey *****? - it is possible to jump the 2-wire IACV pins @ the ECU to two of the three 3-wire IACV pins in the harness and fool the ECU so it doesn't throw an IACV code. This totally disables the 3-wire IACV, and will require you set your idle via throttle stop and airbleed screw on the TB.
bagged_accord96
Jan 18, 2009 10:02 PM
PinoyxEJ6
Audio / Security / Video
Jun 11, 2007 07:11 PM
Hapexamendios EJ8
May 9, 2005 09:39 AM
mikecivichb
Apr 4, 2004 10:05 AM
