Intercooler size
Is the intercooler size of 31 1/2 x 8 x 3.5 too big. Its the precision 600hp intercooler.
This is for a 98 integra gsr.
I dont know If I should go smaller something like 28x7x3.
Whats are you guy's using.
thanks
thanks
you dont need the biggest intercooler you can find......
here is my street car build from last year. it had an intercooler that mesured 17 end tank to end tank/ 11 tall. (spearco core)
~450hp /315 torque on pumpgas, through a 2.5inch exhuast.
https://honda-tech.com/zerothread?id=1549069
What intercooler size are most of you guys using on the third gen integra's.
Would an intercooler at the size of 31 1/2 x 8 x 3.5 fit.
that is the precision 600hp intercooler.
Can anyone help
Can anyone help
I'm using the 350 hp Precision intercooler. It's almost 2 inches shorter (height wise) and barely fits. If you cut the bumper support you can fit the 600 hp version. I didn't want to cut it... I'm making 267 on a Mustang dyno...
Yeah I dont want to cut out the bumper support. I want to only cut out the grill in front.
What do you mean by barely fits. Are you talking about the width of it. Or the height.
If im sure the precision 350hp intercooler is 26 1/2 x 6.20x 3.5
26.75L x 6.20H x 3.50D-2.5" I/O---->350hp
31.50L x 8.00H x 3.50D-2.75" I/O--->600hp
31.50L x 10.30H x 3.50D-2.75" I/O-->750hp
34.50L x 10.50H x 3.50D-2.75" I/O-->825hp
--These are Precision Intercooler Sizes with what hp they rate them...Common Intercoolers range anywhere from 8"-10" in height...If your trying to fill a cut out mouth, a 6" wont look right.
When you say trim out the bumper. Are you talking about the plastic grill part. Or the core support frame.
Thats all im confused on.
If its only the plastic grill part then im going to buy one of these next week.
If your looking to keep bumper support, then the 26.75L x 6.20H x 3.50D-2.5" I/O---->350hp is the only Precision Intercooler that will fit without hanging to low.
Now should I invest on buying a front lip kit. Because of the intercooler hanging low. Also for the thickness of the intercooler. How much room does most you guys have.
Yesterday I measured 6inchs from the radiator to the plastic grill on the bumper cover.
Will I have enough space between the radiator and the grill
I want to just trim the grill. Not fully cut it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboJesse »</TD></TR><TR><TD CLASS="quote">You can also notch your bumper support so that 8" Cores don't sit too low. Takes a few minutes with a cut off wheel
LordAphotic
Welding / Fabrication
Aug 8, 2006 07:28 PM
