intercooler piping....different sizes, is that a problem?
I'm thinking about using my AEM CAI to run the piping from the intercooler to the engine. But the piping that I've got is only about 1 3/4 inches and the CAI is like 3 inches, or something...all I know is it's a lot bigger. I'm going to run the 1 3/4 piping from the turbo to the intercooler. So will having a larger piping on one end of the IC and a smaller one on the other be a problem with boosting?
Its ok to have smaller piping from the turbo to the intercooler but I wouldn't suggest using 3" piping from the intercooler to the throttlebody, it is way to big for a low boost application. You really only need 2 1/4" in your situation. IMO
Right on people, that's what I figured. Cool...I guess I'll just sell my CAI and get the piping done right.
Thanks for your input.
Smarter than you
bigger piping is just gonna add more lag. if u have the choice between two sizes of piping most people will tell u to go with the smaller size to keep velocity high. in our cars we have a long distance to travel from the turbo-IC-manifold. at 3" its probably gonna add ALOT more lag if u think about how much extra volume that is to fill before u can have pressure.
most people on H-T run 2 1/4" piping, and some of the high horsepower guys upgrade to 2 1/2".
[Modified by DIRep427, 3:45 PM 1/16/2003]
1 3/4" is fine for a low boost, low $ setup. You can get away with running half small, half large piping. Your throttle body is larger than 1 3/4" anyways, so either way the opening is going to get larger at the end of the 1 3/4" pipe. It might spool up a little bit sooner if you ditch the big pipe though. You can use the CAI, but I would ditch it.
What type of charge pipe does the dms's use because they're flexible and pretty easy to work with. Where can I find more of this so I can run it back to the trottle body. Is it just like the radiator hose?
why is 3" too big?
I had planned on doing the same thing...
what problem could bigger piping cause?
it seems to me with as much cfm as the average t3/t4 turbo flows, the time it would take to fill the extra .5" of tubing (about 8.6 cubic feet in a 4 ft section I believe) of space would be a fraction of a second
when it all comes down to it it makes more sense for me to sell my aem intake while it is worth something and make new charge pipe, I am just thinking theory and I think the aem looks good
[Modified by Phoenix GSR, 12:05 AM 1/17/2003]
sup hawaii! iwouldHITit isn't exhaust piping kinda heavy? I'm either going to find a cheap muffler shop that can make custom pipes...or I'm going to go the junk yard and find them and cut and clamp them together.
