Intercooler pipe needs bending
Old Jan 7, 2004 | 07:27 AM
RedTegLS's Avatar
Default Intercooler pipe needs bending
The intercooler pipe that comes off the bottom of the turbo needs to be bent about 1/2". It hangs to low to the ground. Now on locally can bend the pipe how can I do it myself? Is it even possible?
Old Jan 7, 2004 | 07:40 AM
DaveF's Avatar
Default Re: Intercooler pipe needs bending (RedTegLS)
could you possibly cut the pipe a bit to make it fit better?
Old Jan 7, 2004 | 07:48 AM
RedTegLS's Avatar
Default Re: Intercooler pipe needs bending (2.2Lcivic)
Here is the thing....its a Greddy type 31 kit and it has an elbow after the pipe from the intercooler. What i need to do is be able to bend the pipe that comes off the bottom of the turbo so I can turn the elbow up and get it away from the ground. Does that make sence?
Old Jan 8, 2004 | 06:05 PM
DaveF's Avatar
where is hicktown PA, maybe if you are close by i can give you a hand.
im located about 30min north of philadelphia.
Old Jan 8, 2004 | 06:42 PM
RedTegLS's Avatar
Damn I wish! I am about 2 more hours north of you. What are you thinking? I called every fabricator in my area and the biggest pipe they can bend is 1.5". Is there a diff between bending aluminum and steel?
Old Jan 8, 2004 | 07:42 PM
DaveF's Avatar
does it only need a slight bend? im almost sure any muffler shop would be able to do the trick. and not crush the tubing
if that doenst work, i have an extremly capable fabricator that will definitly be able to figure something out.
Old Jan 15, 2004 | 05:52 AM
RedTegLS's Avatar
What about a 90 degree bent hose coupler right off the bottom of the turbo? Then I could cut 90 degree off the pipe and put it stright in. Anywhere to buy a 90 Degree bent hose other then http://www.turbohoses.com?
Old Jan 15, 2004 | 07:29 AM
xenocron's Avatar
http://www.dnaparts.com/hoses.htm#90°%20Elbows
http://shop.airflowonline.com/...nt.mv
Old Jan 15, 2004 | 07:34 AM
RedTegLS's Avatar
Default Re: Intercooler pipe needs bending (xenocron)
OMG you f*cking rule! Those are perfect. Thank you SOOOOO much!
Old Jan 15, 2004 | 12:42 PM
xenocron's Avatar
Both places very friendly and helpful and the 90 hooked DIRECTLY to my compressor is holding up very nicely...i have a 2nd spare on hand for any troubles
Old Jan 15, 2004 | 12:49 PM
Blown96GSR's Avatar
you know any exaust shop in your area will be able to bend the pipe for you at very little cost!! FYI!!
Silentxracer
Texas -OK -LA (Sales)
Jan 10, 2011 05:06 PM
clemsonteg
Jun 1, 2006 07:16 AM
otto
Aug 31, 2005 07:22 PM
Sport_Injected
Oct 30, 2004 04:34 AM
Aeka GSR
Apr 8, 2002 03:12 PM
