Intercooler Mounting???
Old Nov 7, 2005 | 06:55 PM
trickmaster505's Avatar
Default Intercooler Mounting???
I've been looking around for a FMIC for my teg and I came across this one with "mounting tabs" and I was wondering if I just drill a short bolt into these and connect with an L-bracket or something. Please let me know.
Modified by trickmaster505 at 12:46 AM 11/8/2005
Old Nov 7, 2005 | 09:12 PM
Default Re: Intercooler Mounting??? (trickmaster505)
anyone?
Old Nov 7, 2005 | 10:27 PM
darkdayz's Avatar
your pick didnt come up for but I always try and mount it in three section ....I dont think there is any correct way as long as it's secure and functioning
Old Nov 7, 2005 | 11:47 PM
pics fixed
Old Nov 8, 2005 | 03:52 AM
JSPECSIR's Avatar
LOTS of duck tape and velcro. jk. I was looking at that exact intercooler. I think your supposed to drill and tap those mounting locations and then use L brackets. anyway yeah what you said.
Old Nov 8, 2005 | 08:16 AM
Deluzional's Avatar
Default Re: Intercooler Mounting??? (5THGENSI)
that looks like a thick piece of metal to drill into, from the looks id just weld the L brackets onto those tabs
Old Nov 8, 2005 | 08:51 AM
null.'s Avatar
Default Re: Intercooler Mounting??? (Deluzional)
yeah i think welding a bracket on there is your only solution
Old Nov 8, 2005 | 09:15 AM
RyanEJ8's Avatar
Default Re: Intercooler Mounting??? (EG6JUNKIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6JUNKIE &raquo;</TD></TR><TR><TD CLASS="quote">yeah i think welding a bracket on there is your only solution</TD></TR></TABLE>
It's the best solution anyways.
Old Nov 8, 2005 | 04:19 PM
yee SERIOUS's Avatar
i think welding L brackets to the top would be the best. that's what i did too. i like that IC. where did u find it?
Old Nov 8, 2005 | 06:20 PM
Default Re: (undercoverdc2)
ebay.... http://cgi.ebay.com/ebaymotors...%3AIT
Old Nov 9, 2005 | 07:50 PM
TheThiefTheKnife'NTheGun's Avatar
Default Re: (trickmaster505)
I popped holes in the bottom of the bumper support with a torch and then welded nuts in the holes on the bumper support got some bolts and bolted the cooler right up..
Old Nov 9, 2005 | 10:00 PM
2point2's Avatar
Default Re: (TheThiefTheKnife'NTheGun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheThiefTheKnife’NTheGun &raquo;</TD></TR><TR><TD CLASS="quote">I popped holes in the bottom of the bumper support with a torch and then welded nuts in the holes on the bumper support got some bolts and bolted the cooler right up.. </TD></TR></TABLE>
thats what i did! accept i drilled holes.. i used nuts similar to the ones pictured.
I drilled a hole big enough for the 'nut' part and tack welded the washer part to the unibody.
grabbed some L shaped aluminum from the hardware store and made some brakets. I just scribbed where i wanted them and brought the IC and brakets to a shop to tig weld them on. looks clean and works great.
redboost10
Aug 2, 2006 08:50 AM
meanB6teen
May 8, 2005 11:41 AM
W O T
Jan 14, 2005 11:35 PM
pissedoffsol
Aug 13, 2003 02:58 PM
TurBoXBirD16
Jul 29, 2002 06:31 PM
