Custom Intercooler Brackets, will these work?
Old Jul 28, 2002 | 11:24 PM
TurBoXBirD16's Avatar
Default Custom Intercooler Brackets, will these work?
I am getting my intercooler soon, i want to see what I should to do mount the intercooler
I don't know how to weld nor i know anybody would do it for me cheaply...
then I found these brackets at my work place (not really my work place)
then I think I might be able to use these to mount my intercooler and my pipes
here is my plan, use this bracket to secure the Intercooler pipes outside the silicone hose, then use that holes to connect to a piece of metal, then bend that piece of metal and mount them to my car's body...
that means i am using ONLY two of these mounts, DO YOU GUYS THINK IT'S ENOUGH?
Then I can use one more of this bracket to hold one of my pipes... good idea??
I drew a picture of what i am going to do, give me some opinions
i know welding is always the best, but i really don't want to spend 50 bucks for somebody just to weld few pieces of metal
Old Jul 29, 2002 | 03:22 AM
RGAZ's Avatar
New User
Default Re: Custom Intercooler Brackets, will these work? (xbird)
IMO
Does it ahve to actually support the weight of the intercooler? or is the intercooler sitting on a shelf or something? Will the intercooler bump or rub something else? (it would be bad if it does).
How else is it supported?
Randy
Old Jul 29, 2002 | 04:48 AM
quis23's Avatar
Default Re: Custom Intercooler Brackets, will these work? (RGAZ)
If you know welding is the best;why not just spend the $50.00!! Don't be cheap,do it right!!
Old Jul 29, 2002 | 05:27 AM
CovertFI's Avatar
Default Re: Custom Intercooler Brackets, will these work? (quis23)
if your car was not a daily driver i would say half *** it, but since it is weld the brackets. between hitting bumps in the road and the movement of your engine your ic will bounce around alot.
Old Jul 29, 2002 | 05:47 AM
len's Avatar
len
Default Re: Custom Intercooler Brackets, will these work? (CovertFI)
Very true. You need to really support the intercooler and not the piping. Once the intercooler is bolted up, it will support the intercooler piping. If you only support the intercooler piping, then the intercooler may actually move around and vibrate alot. Don't take shortcuts, because it will show up later and haunt you. Do it once and do it right.
Old Jul 29, 2002 | 09:56 AM
Default Re: Custom Intercooler Brackets, will these work? (iloveracing)
i am saying use the brackets ON the intercooler's inlets and oulets
then connect those brackets with a metal, then bolt that metal to the car's body
i know that if the intercooler is secured good, i don't need to mount the pipes
but i can still use these bracketst to hold the pipes better, right??
Old Jul 29, 2002 | 11:49 AM
Smashback's Avatar
SPEND THE BUCKS AND HAVE SOMEBODY WELD ON BRACKETS. That thing is heavy, it will vibrate all over the place with those hose deals.
BTW, My piping vibrates and rattles sometimes and annoyed the crap out of me..well since I just bought a welder I welded some bar steel brackets from the pipes on each side and bolted them to the bumper bolts. No more rattles
[Modified by mplex2000, 8:50 PM 7/29/2002]
Old Jul 29, 2002 | 12:04 PM
Full-Race Geoff's Avatar
please weld pieces of angle on the top. if you need the pieces, let me know. Just do it right, your intercooler will thank you by not ending up on the interstate. ... and yes i saw what an IC looks like after its been dragged along the highway at 80.
Old Jul 29, 2002 | 12:07 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Custom Intercooler Brackets, will these work? (mplex2000)
Go to a place like midas or another muffler shop, they'll make small welds for 20 dollars. A hangar broke off of my racing medalion on the muffler. I took it to them and 10 minutes and 20 dollars later it was fixed, a little weld will not cost you much at all and it'll save u a lot of trouble down the road (literally).
Old Jul 29, 2002 | 02:06 PM
Default Re: Custom Intercooler Brackets, will these work? (PreIudeSI)
midas cant weld aluminum. at least no midas's that i know of... (except for arvin's midas heh)
Old Jul 29, 2002 | 02:16 PM
Default Re: Custom Intercooler Brackets, will these work? (FFgeoff)
okok... hehe
thanks
Old Jul 29, 2002 | 02:33 PM
oh also,
should I use aluminmum metal brackets to weld on the intercooler?
and the pipes?
Old Jul 29, 2002 | 02:42 PM
PrecisionH23a's Avatar
JB WELD IT! sike, take it to a welder to get it done. the brackets would work im sure and the pipes on the endtanks are welded to the intercooler (which will probably support the intercooler just fine) but its always better to do it right the first time.
Old Jul 29, 2002 | 03:09 PM
Default Re: Custom Intercooler Brackets, will these work? (GudeH23a)
i will just take it to a mufflr shop and weld them
Speedy is probably the place to go ?
Old Jul 29, 2002 | 06:31 PM
Ri5e's Avatar
definetly get it welded, you have some ghetto ideas
redboost10
Aug 2, 2006 08:50 AM
meanB6teen
May 8, 2005 11:41 AM
civcexcoupeblack
Sep 26, 2003 10:24 AM
pissedoffsol
Aug 13, 2003 02:58 PM
88crxvtec
Apr 8, 2003 08:41 AM
