Intercooler Mounting???
I've been looking around for a FMIC for my teg and I came across this one with "mounting tabs" and I was wondering if I just drill a short bolt into these and connect with an L-bracket or something. Please let me know.
Modified by trickmaster505 at 12:46 AM 11/8/2005
your pick didnt come up for but I always try and mount it in three section ....I dont think there is any correct way as long as it's secure and functioning
LOTS of duck tape and velcro. jk. I was looking at that exact intercooler. I think your supposed to drill and tap those mounting locations and then use L brackets. anyway yeah what you said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6JUNKIE »</TD></TR><TR><TD CLASS="quote">yeah i think welding a bracket on there is your only solution</TD></TR></TABLE>
It's the best solution anyways.
I popped holes in the bottom of the bumper support with a torch and then welded nuts in the holes on the bumper support got some bolts and bolted the cooler right up..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheThiefTheKnife’NTheGun »</TD></TR><TR><TD CLASS="quote">I popped holes in the bottom of the bumper support with a torch and then welded nuts in the holes on the bumper support got some bolts and bolted the cooler right up.. </TD></TR></TABLE>
thats what i did! accept i drilled holes.. i used nuts similar to the ones pictured.
I drilled a hole big enough for the 'nut' part and tack welded the washer part to the unibody.
grabbed some L shaped aluminum from the hardware store and made some brakets. I just scribbed where i wanted them and brought the IC and brakets to a shop to tig weld them on. looks clean and works great.
TurBoXBirD16
Jul 29, 2002 06:31 PM
