intercooler flow?!
Old Mar 7, 2007 | 08:19 AM
  #26
b18sihatch's Avatar
Default Re: (Schister66)
money seems to be an issue but if it wasnt i would go with a ported head and a good valve job, that will definitly yeild you some power. but you are talking some money
  #27
TurboJesse
Guest
Posts: n/a
Default Re: (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch &raquo;</TD></TR><TR><TD CLASS="quote">i imagine themost restrictive part of your setup is infact the downpipe, its probably restricting the flow of the turbo restricting spool time and power, that is what i wouldbe most concerned about, esp making those kinda numbers, it would definitly be the best step before any other, you will see much greater gains with the downpipe over any other upgrade, esp with the setup just the way it is right now, you will def see more gains</TD></TR></TABLE>
Stop giving out bad info.
His turbo uses a stage 3 wheel, with a 2.5" outlet on the housing. He does not need a 3" DP for this power level. Yes it would be an upgrade but wouldn't fix his problem.
Ive seen the same issue with other tial knockoffs 38's..
Old Mar 7, 2007 | 08:24 AM
  #28
PSI2HI's Avatar
Former Vendor
What D series motor is being used? Stock Z6 head will support over 400whp, no its not the most efficient but it'll make the power.
Only thing left here looks to be the FMIC. Get something quality and get away from these 2.5" thick China knock off junk. You'll notice siginificant gains just from a quality core.
Old Mar 7, 2007 | 08:30 AM
  #29
jarvis199's Avatar
yup ug ot the turbo right...
i dont think the head is an issue yet, i do think the dp is, and the ic was, and the wastegates innerds are going to be tial parts now, so im slowly canceling out problems i could be having... tonight im going todo 3" dp nad see how much that helps,e ven if its connected to a 2.5" exhaust
Old Mar 7, 2007 | 08:32 AM
  #30
jarvis199's Avatar
Default Re: (PSI2HI)
yup, its z6, ive got a new fmic, its not the best, but we will see if its good enough, if not im investing in a precision soon...
traxxasx
Aug 20, 2011 11:15 PM
sleepencivic
Jun 22, 2011 11:07 AM
Red D Dragon
Nov 27, 2005 11:39 AM
LSEGHATCH
Apr 16, 2005 07:45 PM
civic disobedience
Aug 1, 2004 08:56 PM
