Head Job
Old Jan 7, 2004 | 06:09 AM
Austinbionic316's Avatar
Default Head Job
Since I have GSR Swap in my Civic EX would I need to port and polish my heads? cause my whp goal is 400whp, and right now my setup is gonna be Hondata s200b, Thermal Exhaust, Golden Eagle Rods, I think its CE Pistons, new valve springs, Im gonna use the stock VTEC head, and Stock cams... I believe thats all... I got a quote tho...my whole engine rebulid from Golden Eagle would be like 3200.00 shipped, so i should be safe to make 400whp on 10-12 psi level right?
Also would it be worth it to hack the ECU for more hp?
Old Jan 7, 2004 | 06:12 AM
ladysman's Avatar
Default Re: Head Job (Austinbionic316)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 &raquo;</TD></TR><TR><TD CLASS="quote">Since I have GSR Swap in my Civic EX would I need to port and polish my heads? cause my whp goal is 400whp, and right now my setup is gonna be Hondata s200b, Thermal Exhaust, Golden Eagle Rods, I think its CE Pistons, new valve springs, Im gonna use the stock VTEC head, and Stock cams... I believe thats all... I got a quote tho...my whole engine rebulid from Golden Eagle would be like 3200.00 shipped, so i should be safe to make 400whp on 10-12 psi level right?</TD></TR></TABLE>
First off, it is HEAD (as you only have 1 on a 4 banger).
It is Eagle Rods
It is CP Pistons
I think you will need a little more boost than that for 400.
Stock head and cams should be fine. Just bump up the boost a little.
Get bigger injectors for the hondata.
Old Jan 7, 2004 | 01:59 PM
Default Re: Head Job (ladysman)
Yea sorry bout the post I was rushing, I had class from 10:15-12:20 so ya know but yeah I have my layout here with me
Eagle Rods
CP Pistons
R/C Injectors 550c
RevHard Stage 3 Turbo
Hondata S200b
Engine Sleeving
Line Boring and hone as well
Crank Sizing
Rod Sizing
and Micro-Polishing The Crank
Thermal Exhaust for my Turbo
So if thats not more than enough to make 400whp+ then I dont know what Is...now this Revhard Turbo stage 3 they said its 200whp kit....so let me get this str8, once the kit is installed right then and there, and dyno...it adds 200whp over stock power?
Old Jan 7, 2004 | 02:56 PM
R THIS's Avatar
what they mean is 200 whp total... but if you are going to build the engine, you can turn up the boost (create more power, with proper fuel & tuning) what turbo do you have?? what intercooler?? if it is all stock revhard stuff you might be pushing it.... just my opinion though, someone correct me if i am wrong!
Old Jan 7, 2004 | 02:59 PM
R THIS's Avatar
also if you are running a hondata, you dont chip the computer, you just run the hondata, and get it tuned.... no need for a chip
Old Jan 7, 2004 | 03:25 PM
allablur's Avatar
Default Re: (R THIS)
its possible id spend a bit more get the p&p done it will help alot imho get probe rods not eagles or upgrade the bolts to arp if u use eagle and get way bigger injectors i got 880s just in case same goals as u on an ls ..
thats my.02 $
Old Jan 7, 2004 | 03:31 PM
R THIS's Avatar
Default Re: (allablur)
i think the injectors are too small, i have 720's for 400 whp, and i wish i had gone bigger
Old Jan 7, 2004 | 05:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R THIS &raquo;</TD></TR><TR><TD CLASS="quote">what they mean is 200 whp total... but if you are going to build the engine, you can turn up the boost (create more power, with proper fuel & tuning) what turbo do you have?? what intercooler?? if it is all stock revhard stuff you might be pushing it.... just my opinion though, someone correct me if i am wrong!</TD></TR></TABLE>
My civic isnt turboed yet...and yeah I was gonna upgrade the turbocharger and intercooler...im not sure on the intercooler or turbocharger..any suggestions?...I dont plan to chip the motor tho... yeah talking about the injectors...um I saw some 700cc injectors from R/C I believe that I want so Imma go through them instead.
Old Jan 7, 2004 | 06:32 PM
Default Re: (Austinbionic316)
DAmN i just found out from http://wwww.turbo-kits.com that I have to remove my AC..DAMN IT!
Old Jan 7, 2004 | 06:38 PM
R THIS's Avatar
personally i am using a precision sc61 and a spearco intercooler the core size is approx. 27 x 8 x 3.. and semen deka 720 cc injectors....
3 inch exhaust, and a throttlebody and intake manifold / head porting may be a good idea for you aswell...
roydogg's Avatar
My friend you have alot of research to do before you start even spending money. Best advice is to read,read, and learn. IF your lookin for over 400whp why go with eagle rods? Spending all that money get some Pauter or Manley rods. Or just give your whole block to Earl and have him let Dan Benson sleeve and build it from bottom to top.
Old Jan 7, 2004 | 06:50 PM
Default Re: (roydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">My friend you have alot of research to do before you start even spending money. Best advice is to read,read, and learn. IF your lookin for over 400whp why go with eagle rods? Spending all that money get some Pauter or Manley rods. Or just give your whole block to Earl and have him let Dan Benson sleeve and build it from bottom to top.</TD></TR></TABLE>
yeah I guess..I just helped with my engine swap..me and my pops did it..but turbo wont be no time soon so pooh on a stick...
Nate8o8_EP3
14
Jan 23, 2020 10:52 PM
Dsbf
48
Mar 2, 2014 10:42 AM
hello1320
18
Dec 14, 2010 09:50 AM
LSracing94
22
Mar 24, 2006 12:01 PM
BlackB18CTeg
Aug 12, 2003 01:40 PM
