integra overheating problem
Old Apr 17, 2005 | 12:13 PM
Evanmb44's Avatar
Default integra overheating problem
so my car has been overheating lately, but only when i have been cruising for a while.
it doesnt overheat just driving in town, even if i hit boost. it overheats if im cruising for a while on the highway, usually close to 3k rpm. im running a del sol radiator and it runs hot to like 3/4 to hot on the temp gauge. it goes back to normal with the heat blasting, but i cant just drive w/ the heat on all the time cause its warm here. ive bled the cooling system, and even changed the mixture. i picked up a new thermostat to see if that helps. dont know if its jsut that or could it be the headgasket?? its not burning coolant and oil is fine too.
i searched but didnt find what i was looking for. please help
Old Apr 17, 2005 | 12:32 PM
s2kdre's Avatar
Default Re: integra overheating problem (Turboaddict)
what kind of a fan are you using? if its not stock where is it mounted in front or behind?
Old Apr 17, 2005 | 12:35 PM
Evanmb44's Avatar
im using a slimfan from pepboys, its mounted in front of radiator as a pusher fan. but the car doesnt overheat when its just sitting, only when cruising
Old Apr 17, 2005 | 12:58 PM
s2kdre's Avatar
Default Re: (Turboaddict)
thats weird it should be opposite, when you're driving it shouldnt get that hot. Maybe the thermostat isnt opening.
Old Apr 17, 2005 | 01:08 PM
Evanmb44's Avatar
i was thinking it may be something wrong with the thermostat, but it warms up fine and to operating temp. then after a while it just gets real hot. i picked up a new thermostat to see if that helps any. should have that put in on tuesday
Old Apr 18, 2005 | 06:46 PM
Evanmb44's Avatar
anyone else?
Old Apr 18, 2005 | 07:38 PM
BoOsTeD C1's Avatar
Did you put on the new thermostat yet?I recently had same problem as you did and it was my thermostat making the temp needle go up and up down...but frum you were describing it sounds like a thermostat problem.Let us know
Old Apr 18, 2005 | 07:40 PM
Evanmb44's Avatar
i will be changing the thermostat tomorrow hopefully. prob wont be able to test it out til wednesday due to work. i will keep it posted
Old Apr 19, 2005 | 12:39 PM
Evanmb44's Avatar
new thermostat in. changed my mixture too w/ a lot more water. i will see if this does the trick
Old Apr 19, 2005 | 02:35 PM
Turbo E's Avatar
feel the upper and lower main coolant hoses. if one is hot and the other is not, its the thermostat. otherwise you may have LOTS of air in the system and it wasnt bled properly.
Old May 4, 2005 | 02:27 PM
Boofster's Avatar
Default Re: (Turbo E)
What's the word on this? I am having the same problem. Only heats up to 75% or so after driving at 3K on freeway for >15mins steady.
I've noticed my overflow tank doesn't seem to get hot at all (not working?) so maybe try the radiator cap.
Almost same setup here, civic PWR radiator with high CFM fan pulling from the back.
Old May 5, 2005 | 02:38 PM
Boofster's Avatar
Default Re: (Boofster)
anyone?
Old May 5, 2005 | 02:46 PM
technine's Avatar
Maybe the new thermostat fixed it and forgot to update. Still need to put in a new one in my girls car as well. Too much to do last weekend. I'm waiting for updates too!
Old May 5, 2005 | 03:02 PM
Tetronious's Avatar
What kind of thermostat you using? (Stock). I tried two different kind from Advance Auto Parts one time and had overheating issues. Took them back and went to the Honda/Acura dealer and picked up a stock one and my problems went away. Did you bleed the system? I think its a screw or bolt underneath the thermostat housing that your supposed to loosen to let the air out of the system. Could also possibly be your engine coolant temp sensor.
Tetronious
00 SI
Boosted
Old May 5, 2005 | 08:44 PM
Evanmb44's Avatar
thermostat was replaced and i also changed the mixture to about 80/20 water/coolant. it still overheats but not as often. did it on the highway after about half an hour or so, and does it if i get into boost a couple of times
Old May 5, 2005 | 09:00 PM
BoOsTeD C1's Avatar
how do you have your radiator fan mounted as pusher or puller?
Old May 5, 2005 | 09:05 PM
Treblarefils's Avatar
If you can get access to a radiator pressure tester test it to see if it will hold pressure and not bleed off. Could have a small leak somewhere and its unoticeable It could cause the radiator to not function properly. My beater car has a bad radiator and leaks no fluid whatsoever. and a small thing try a new radiator cap on it for *****.
Old May 5, 2005 | 09:07 PM
Evanmb44's Avatar
i will try that, i have access to one of those at school. will have to wait til next week tho
Old May 6, 2005 | 04:26 PM
Evanmb44's Avatar
drove it today and wasnt boosting. just driving about 45mph cruisin and it started to get hot.....and my idle fluctuates until it warms up and makes a loud whooooshing sound, like air leaking somewhere until it warms up. any idea what could be the cause???and could that be why im overheating?????
Old May 6, 2005 | 04:46 PM
Evanmb44's Avatar
tttttt
Old May 8, 2005 | 03:51 PM
Evanmb44's Avatar
tttt
Old May 8, 2005 | 04:20 PM
ramennoodles's Avatar
try changing your coolant temp sensor/switch. i think there's two of them. don't remember which does what but you might as well change them both. I had a overheating problem, change the sensors out for new ones and fixed the problem
Old May 8, 2005 | 05:04 PM
Suprdave's Avatar
Default Re: (ramennoodles)
Bleed your coolant...
Old May 8, 2005 | 06:14 PM
Evanmb44's Avatar
i will try changin the sensors. ive bled the coolant a few times already and no luck
cpierich
Feb 26, 2012 06:27 PM
SrVShayner
May 26, 2010 05:04 AM
twenty
Jul 21, 2005 04:32 PM
sol2nr
15
Feb 20, 2004 09:17 AM
LoooseGSR
Jul 15, 2003 10:49 PM
