Int. wastegate "boost source" from upper IC pipe?
Old Jul 21, 2003 | 07:33 AM
DA-MAX's Avatar
Default Int. wastegate "boost source" from upper IC pipe?
just wondering if this can be done "reliably." The outlet pipe on the 1g TD04 I'm using doesn't have a bung on it for the internal wastegate hose to sense boost. I was wondering if instead I could run the wastegate hose up to the upper IC pipe which already has an extra bung welded onto it? would this mess up the response of the wastegate?? heres the thread I found, just wanna make sure this is the right way--> https://honda-tech.com/zerothread?id=111685
Thanks for any advice.
hoochhenry
Welding / Fabrication
Dec 19, 2011 05:13 PM
elevatedj32
Apr 20, 2008 07:02 AM
91glassycrx
May 7, 2004 08:08 AM
BodyKits NW
Nov 3, 2003 12:30 PM
rjardy
May 17, 2002 09:59 PM
