Installing ignition AFTER dyno tuned...
Old Nov 17, 2002 | 09:09 PM
PrecisionH23a's Avatar
Default Installing ignition AFTER dyno tuned...
Dangerous? Car has been dyno tuned already with the hondata, now an aftermarket ignition system and external coil will be installed. Can this lead to any problems?
Old Nov 17, 2002 | 09:15 PM
sweet's Avatar
Default Re: Installing ignition AFTER dyno tuned... (GudeH23a)
i don't see any problems with adding it afterwards. though if you install a really strong ignition system, the motor may need a bit more fuel to compensate for the extra strong spark in the CC just to keep the ratio the same as when it was tuned with the Hondata.
what kind of setup are you using anyway?
Old Nov 17, 2002 | 09:26 PM
Default Re: Installing ignition AFTER dyno tuned... (sweet)
This is actually for my friend, i did the same thing. I had my car dyno'd then later installed the ignition. He didnt listen to me so now he is installing the ignition after the dyno. I told him he would be fine. For my application i am using the crane hi6r with ps92 race coil. Here were my a/f ratio's on the dyno... it was tuned on the rich side because i knew i would be installing the ignition system shortly afterwards.
Old Nov 17, 2002 | 09:48 PM
sweet's Avatar
that looks like a nice ratio though it is rich, IMO he'd be fine adding the ignition system after the tuning was done. but i'm not an expert at this stuff.
Johnny_9
Jul 13, 2006 11:16 PM
EikoU
Feb 8, 2006 12:21 PM
PrecisionH23a
Sep 29, 2004 08:31 AM
30psi Teg
Mar 1, 2004 08:45 AM
austrian type-R
Aug 10, 2002 01:28 AM
