Installing Front Mount Intercooler ON Teg.
Old May 9, 2003 | 02:17 PM
  #26
BlackB18CTeg's Avatar
Default Re: Installing Front Mount Intercooler ON Teg. (RyanAutry)
i have a 9.6 volt drill......
Old May 9, 2003 | 02:19 PM
  #27
Default Re: Installing Front Mount Intercooler ON Teg. (BlackB18CTeg)
how do you route the tube around the driver side?
Old May 9, 2003 | 02:35 PM
  #28
Rain_man's Avatar
New User
Maybe you have a old drill bit? Or something that doesn't drill metal well?
Old May 9, 2003 | 06:21 PM
  #29
99ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackB18CTeg &raquo;</TD></TR><TR><TD CLASS="quote">how do you route the tube around the driver side?</TD></TR></TABLE>
Old May 9, 2003 | 07:28 PM
  #30
turbopimp's Avatar
Cut a hole in the plastic splash panel on the drivers side. You can use a knife if you don't have a hole saw. Be sure to eyeball the pipe coming off the turbo first, this will take the guess work out and minimize the cutting. The pipe runs underneath the windshield wiper fluid reservior.
Old May 9, 2003 | 08:51 PM
  #31
Kutsuju_SLeePER's Avatar
Default Re: Installing Front Mount Intercooler ON Teg. (turbopimp)
Here u go
I just did mine last week
Use the BUmper Beam Support
On the FMIC there should be tabs to drill holes in or weld. Drill holes in it. U can use the stock HOLES from the BEAM as a guide and use as well
If u look Closely at the top beam. U can see where we kinda made the holes a little bit bigger. We used large screws and a big enough washer to make sure it wouldnt fall through
WOO HOO
No cutting required in the bumper
This is a 96 GSR
Good luck
Only took like 20 min to install
Easiest part of the whole setup
Old May 9, 2003 | 08:53 PM
  #32
Default Re: Installing Front Mount Intercooler ON Teg. (Kutsuju_SLeePER)
Oh yeah , u canjust bend the AC line outta the way no problem.
Old May 9, 2003 | 09:28 PM
  #33
99ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kutsuju_SLeePER &raquo;</TD></TR><TR><TD CLASS="quote">Here u go
WOO HOO
This is a 96 GSR
Good luck
Easiest part of the whole setup</TD></TR></TABLE>
Got any pictures of the intercooler piping? Particularly the driver side from the turbo to the intercooler.
Old May 10, 2003 | 10:18 AM
  #34
Default Re: Installing Front Mount Intercooler ON Teg. (99ls)
I do but not donwloaded from Camera yet
Here is a pics of the Piping from the Passenger side though
what u need the driver side pic for?
Ill take more pics this week as my car is sitting at the shop calling my name waiting for me to fix her up.
Old May 10, 2003 | 02:22 PM
  #35
nice pics, only my tabs are the L tabs, but I got it mounted No Problem already. I would also like a peak at the driver side....... I hate your ***.... Haha not really. I envy you.... HYdrolic LIFT I want one of those bad boys. I have to use Jackstand
Old May 10, 2003 | 03:45 PM
  #36
99ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kutsuju_SLeePER &raquo;</TD></TR><TR><TD CLASS="quote">I do but not donwloaded from Camera yet
I will be making some custom piping and wanted to get a general idea of how they're routed.
Old May 10, 2003 | 07:41 PM
  #37
Ahh ok
Well im here in germany and on pretty good terms withthe HONDA dealership here. They let our crew Wrench on our cars after business hours. FREE tools and ****, helll yeah. But i will end up finishing her off this week. I got the Drivers side on now. Just need to Download the pics. Ill try to hook u up soon ok.
Old May 10, 2003 | 07:43 PM
  #38
The driver side is pretty basic for the integra
Its about the same bend like onthe Passenger side exept it Straight after the bend. Its does not go up. Then u have another small pice that bends up to the Turbo. DO u knwo what i mean?
Old May 16, 2003 | 11:07 AM
  #39
kaj's Avatar
kaj
i ran the a/c line (the one that sticks way out in front of the power steering lines) BEHIND the power steering lines. simply unbolt the p/s "loop", bend it out (the rubber lines allow it to move rather freely), and bend the a/c line back. put the p/s line OVER the a/c line and bolt it back to the bracket. worked perfectly. i'd post pics on here if i knew how
also:
has anyone cut the bumper support to allow the intercooler to set a bit higher? i'd like mine about 2" higher. right now the bottom of it sits behind the bumper cover.. probably not getting much air. anyone "notched" a support???
blackdude
May 8, 2006 12:20 PM
Stewie
Welding / Fabrication
Aug 30, 2005 12:37 PM
meanB6teen
May 8, 2005 11:41 AM
88crxvtec
Apr 8, 2003 08:41 AM
VTEC-DA
Feb 3, 2003 05:22 PM
