DSM injectors, do you use honda oem o-rings or dsm o-rings?
I have dsm o-rings on my 450's now, they seem thicker than the honda o rings. well right now they are cracked a little, and leaking. i have to change them, should i get honda o rings or the dsm eclipse ones?
btw im talking about the o ring for the top of the injector that plugs into the fuel rail.
Re: DSM injectors, do you use honda oem o-rings or dsm o-rings? (pennhatch)
I'd probably go with the ones for the injectors (the 450 o rings). I am using dsm 450s with their o rings and they fit & work fine. Good luck.
Re: DSM injectors, do you use honda oem o-rings or dsm o-rings? (eastbay92cx)
thanks for the simple answer. i will be ordering them from chrysler tomorrow.
ive used like 3 sets of dsm injectors over the years. you use the stock o rings from the honda, but you have to bore them out a tiny bit. i find that you can put the oring inside like a 16 or 18mm socket and just use a dremel tool to go around the inside for a min or too. take off in small increments, cuz you cant put the material back on once you remove it. just keep trying till the fit nice and bam! done deal.
ps make sure you remove the tab from inside the injector plug
Re: DSM injectors, do you use honda oem o-rings or dsm o-rings? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote"> ive used like 3 sets of dsm injectors over the years. you use the stock o rings from the honda, but you have to bore them out a tiny bit. i find that you can put the oring inside like a 16 or 18mm socket and just use a dremel tool to go around the inside for a min or too. take off in small increments, cuz you cant put the material back on once you remove it. just keep trying till the fit nice and bam! done deal.
ps make sure you remove the tab from inside the injector plug </TD></TR></TABLE>
wait are you talking about the ones that go in the intake mani? cuase i just slam them in there and torque doesn the 3 ten millimeter rail bolts
im talking about the ones going into the intake manifold. the big fat ones. the ones on the top im pretty sure ive used both civic and dsm ones, jusst be careful not to pinch the o ring when installing into the rail or it will **** gas all over the place
TurbothisLS
09-30-2002 06:25 AM
