Installing Catch Can and stripped a fitting on the back of block....HELP!!!!
Old Jul 3, 2007 | 02:27 PM
JoeZeE's Avatar
Default Installing Catch Can and stripped a fitting on the back of block....HELP!!!!
I don't know what to do anymore...I'm going insane!! I had a helluva time trying to get these two fittings off. I got a breaker bar today and was able to get one fitting off but now the other one is stripped. I tried using epoxy to mold in the hole but that didn't work and now I'm getting really frustrated because I'm running out of ideas! Please help!!!!
Old Jul 3, 2007 | 02:39 PM
da_dude's Avatar
So you strip the allen wrench shape to a circle huh? I did the same too. Just weld that bitch to a nut and take it out. Came right off. Heat will help too. Don't know if you have excess to a welder though.
A.E Motoring's Avatar
Default Re: Installing Catch Can and stripped a fitting on the back of block....HELP!!!! (JoeZeE)
try to go a size bigger and hammer the bitch in there and break it loose
Old Jul 3, 2007 | 02:45 PM
JoeZeE's Avatar
I'll try to go a size bigger and see if I have any luck. Hvae a friend who's a welder also, I'll see if he can help. Thanks for the suggestions, I'm going crazy over here!!
Old Jul 3, 2007 | 02:51 PM
JoeZeE's Avatar
If it doesn't come out though, is it possible to drill it out or even find another place on the block to run the line OR just run one line??
Old Jul 3, 2007 | 04:25 PM
Default Re: (JoeZeE)
i have seen ppl just run one line
Old Jul 3, 2007 | 05:44 PM
JoeZeE's Avatar
is there any negative effects of just running one line?
Old Jul 3, 2007 | 05:45 PM
well 2 is better, but one is better than none, lol
Old Jul 3, 2007 | 06:48 PM
a1320addict's Avatar
Default Re: (Dual Cam Racing)
Try a Torx bit of a bit bigger size than the 14mm hex.
If you can't get to a welder, a little jb-wled can go a long way
Old Jul 3, 2007 | 06:50 PM
bigbadboy's Avatar
should have tried and impact 1st. def try to weld a nut on there or something.
Old Jul 3, 2007 | 06:54 PM
Jared's Avatar
air chisel
Old Jul 3, 2007 | 07:08 PM
JoeZeE's Avatar
I'm JB welding the key right on there as we speak and I'm going to let it cure overnight most likely. I was stupid and tried to take it off with just a ratchet last night. I bought a breaker bar today and the other came off like magic but this one was too stripped already. You live and you learn I guess.
Old Jul 3, 2007 | 07:28 PM
Muckman's Avatar
Moderator in Chief
Theres no way JB weld will hold. It will just sheer off in 1 second, you'll see.
Old Jul 3, 2007 | 07:35 PM
BrockNB's Avatar
weld a bolt to it.
Old Jul 3, 2007 | 08:48 PM
da_dude's Avatar
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Theres no way JB weld will hold. It will just sheer off in 1 second, you'll see.</TD></TR></TABLE>
True that!
Welding a nut there will create enough heat for it to come off easier. I have done it with a impact gun and no luck. Even try the breaker bar but just shread it round. Last resource was welding it and it came out.
Old Jul 3, 2007 | 10:39 PM
JoeZeE's Avatar
Default Re: (turb20_vtec)
It is looking like that is what I'm going to have to do. I don't have any welding equipment so I have to see if my coworker can weld one on for me. *fingers crossed*
Old Jul 4, 2007 | 10:04 AM
Bailhatch's Avatar
nothing like welding over epoxy AND jbweld. do your friend a favor and clean the hell out of the plug before he gets there.
Old Jul 6, 2007 | 02:26 PM
JoeZeE's Avatar
Problem solved!! My friend came over today and he welded up a bolt to the plug and it came off so quick! Thanks for the suggestions guys...much appreciated!
Mr HYDE
Apr 2, 2007 07:40 AM
FOrSfEd
Sep 4, 2004 09:55 AM
