Installing 450's in obd2 Integra....
Old Apr 22, 2004 | 08:11 AM
Smooth-GSR's Avatar
Default Installing 450's in obd2 Integra....
I did search, but still have a question...
I have a b18b obd2 Integra that we are switching to obd1 and chipping ecu. I would like to put in my dsm 450 injectors this weekend and I want to make sure I have everything.
I of course have the injectors, I also have a resistor box but I know that I need obd1 injector clips. I do have a whole obd1 integra fuel rail with injectors, so I'm assuming I can use parts from there. What exactly do I take from there to make the injectors fit my obd2 car? Do I have to cut the wires going to the clips and solder them onto my fuel rail then put the 450s into those 'clips'? Or is it something else???
Thanks in advance!
Old Apr 22, 2004 | 08:14 AM
TurboBumblBee's Avatar
Default Re: Installing 450's in obd2 Integra.... (Smooth-GSR)
u need the obd1 injector harness and clips from the obd1 engine harness.. u can buy them for 10 bux for the harness, i forgot where i saw them but they arent that expensive if youd ont have the whole injector plug harness
Old Apr 22, 2004 | 08:17 AM
Smooth-GSR's Avatar
Default Re: Installing 450's in obd2 Integra.... (Boostfedb18c1)
I do have an obd1 integra fuel rail with injectors still on it. Isn't that what I need? What exactly do I remove from that and put on my car.... do I cut the each injector harness and solder them onto my rail??? Or is this something I can just pull off and put onto my car...
Old Apr 22, 2004 | 09:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smooth-GSR &raquo;</TD></TR><TR><TD CLASS="quote">I do have an obd1 integra fuel rail with injectors still on it. Isn't that what I need? What exactly do I remove from that and put on my car.... do I cut the each injector harness and solder them onto my rail??? Or is this something I can just pull off and put onto my car...</TD></TR></TABLE>
you need these...
http://www.importparts.com/sho...=2765
they can be cut off an engine harness from an obd1 car...
jayswizz
Feb 15, 2014 04:47 AM
Superqwak
Aug 16, 2012 09:00 PM
Gofmf
Oct 24, 2009 01:14 AM
98-DC4
Aug 26, 2009 08:12 PM
Andre
Dec 20, 2003 09:38 AM
