installed 550's, now running way to lean??.....
Old 06-06-2005, 06:30 AM
blackeg's Avatar
Default installed 550's, now running way to lean??.....
i installed some low impedance 550's last night, and its running way to lean. originally idle a/f was in the low 20:1 range, i added about 30% more fuel back in with the uberdata, but that only brought it down to 18:1. (this is a .bin that was working fine with 440s and i just changed the injector size and now this). i soldered in the inline resistors to the yellow/black power wires for each injector as well. anyone have ideas. im trying to figure out if its a problem with the injectors/my install if its related to uberdata. i was planning on the dyno tonight too
Modified by blackeg at 1:28 AM 6/13/2005
Old 06-06-2005, 07:20 AM
raene's Avatar
Default Re: installed 550's, now running way to lean??..... (blackeg)
Pulled the plugs yet? Are all the injectors firing?
Old 06-06-2005, 09:27 AM
dustin's Avatar
Big injectors take a long time to open, so you have to add lots of fuel at low pulsewidth (idle).
Old 06-06-2005, 12:41 PM
blackeg's Avatar
Default Re: installed 550's, now running way to lean??..... (dustin)
i downloaded another .bin file that was already using 550's. after a minute of idling at around 17:1, it dropped back down in the 14's. vacuum is still lean but boost in in the low 11's. i wonder if i was just using a bad chip(even though i tried a few) because one of these times i threw a solid cel.
Old 06-06-2005, 03:47 PM
TunerToys's Avatar
If you do find a problem with the injectors, just let us know and we'll immediately take care of it. Sounds like you are making progress on the solution though.
Good Luck, and let us know how it goes.
Craig
Old 06-06-2005, 06:31 PM
wisjdmhonda's Avatar
Default Re: installed 550's, now running way to lean??..... (TunerToys)
bump
Old 06-06-2005, 09:32 PM
blackeg's Avatar
Default Re: installed 550's, now running way to lean??..... (wisjdmhonda)
hey guys thanks for all the replies. the injectors are working wonderfully (they start up better than my rc440s did too ). the problem is now fixed and my boost is up a few more psi . as of now im chalking it up to using a bad chip/getting a bad burn. i probably had some static electricity and fried the chip, or maybe just needed to restart my computer....
Old 06-07-2005, 05:57 AM
Glad to see you got that fixed.let me know how much power you make on the dyno!
Old 06-07-2005, 06:24 AM
blackeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wisjdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">Glad to see you got that fixed.let me know how much power you make on the dyno!</TD></TR></TABLE>
definately will
Old 06-12-2005, 08:09 PM
blackeg's Avatar
bleh, day before the dyno and it happend again. i went to reburn and pull a few % in vacuum so i wouldnt suck gas on the highway, and now i cant get a decent running map. fuel values on the wideband are down into the 8's in boost (mind you i didnt touch the boost maps), and jump well over 20:1 at idle, and when i take my foot off the gas, it still reads like 17:1 and my injectors should be shut. so far i've tried...
restarting my computer
unplugging and replugging in my burner
making a scratch basemap
downloading and using both premade and basemaps with uberdata 1.7 (was using 1.6666)
using both brand new never used and also previously functional chips
sometimes ill get solid cel, and other times it will work fine just run all over the place. this is using the moates usb burn1 unit. the wideband sensor is still pretty on point, reading just about 20.9% o2 free air....
Old 06-12-2005, 08:43 PM
mtber's Avatar
Sounds like your having fun with uberdata bugs (currupt files etc)
You may want to consider looking into crome
Old 06-12-2005, 09:06 PM
used2baracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Big injectors take a long time to open, so you have to add lots of fuel at low pulsewidth (idle).</TD></TR></TABLE>
very true... larger p&h injectors are not linear, meaning you have to add a lot or take a lot out where as with tuning stock injectors, you take a little out on the map, and a little comes out on the a/f ratio. Uberdata is buggy/hard to tune so if you keep trying to tune like you are (burning a rom and go back), you are gonna own yourself... I have to make so many changes when tuning with uberdata that it's rediculous, and then sometimes after everything looks good, it goes back and does things such as what you are experiencing. Not knocking uberdata, but if you wanna run it, you better invest in a romulator.
Old 06-12-2005, 09:28 PM
blackeg's Avatar
Default Re: installed 550's, now running way to lean??..... (used2baracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by used2baracer &raquo;</TD></TR><TR><TD CLASS="quote">
if you keep trying to tune like you are (burning a rom and go back), you are gonna own yourself....</TD></TR></TABLE>
yea tell me about it, i had it too man, almost perfect, just got greedy or something. right now im running a virus scan on my comp just in case.
i get what you are saying about the larger pulsewidth and all, but i seriously just pulled 2% of a small part of my vacuum map and then everything is whacked out... after that i put the 2% back in and its still all over the place. gonna try to mess with it more tomorrow. im just trying to figure out if its a problem with my burner itself, cause i'd have to get it sent back out to be looked at
Old 06-12-2005, 09:31 PM
if it's ur burner, you'd more than likely have solid check lights and unreadible chips.
Old 06-13-2005, 06:15 AM
blackeg's Avatar
yes i know, and like every 5 burns i do i get a solid light... grr
Old 06-13-2005, 08:43 AM
dustin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">bleh, day before the dyno and it happend again. i went to reburn and pull a few % in vacuum so i wouldnt suck gas on the highway, and now i cant get a decent running map. fuel values on the wideband are down into the 8's in boost (mind you i didnt touch the boost maps), and jump well over 20:1 at idle, and when i take my foot off the gas, it still reads like 17:1 and my injectors should be shut. so far i've tried...
Oh the joy of uberdata Sounds like you are getting your money's worth hehe.
Old 06-13-2005, 04:38 PM
blackeg's Avatar
Oh the joy of uberdata Sounds like you are getting your money's worth hehe.</TD></TR></TABLE>
hahahaha
Old 06-13-2005, 05:23 PM
blackeg's Avatar
ok, just tried burning a whole bunch of different maps, and im left with 3 diff chips that all give me a solid cel . does anyone think its possible that the inline resistors i used are bad and somehow frying my chips due to impedance differences? they were lying in my tool box for the better portion of a year, leftover from my last turbo build.
Old 06-13-2005, 05:24 PM
dustin's Avatar
what burner are you using?
Old 06-13-2005, 08:34 PM
blackeg's Avatar
moates usb burn1 unit. i burnt a resistor in it about a year ago, sent it back and craig fixed it and it has been working flawlessly since (until this if the burner is my problem)
Old 06-14-2005, 12:18 PM
blackeg's Avatar
semi-update: i think my air fuel might only be above 20:1 at idle before i drive it for the first time. also my boost is now 10:1 without changing any settings......
Old 06-14-2005, 12:38 PM
onePOINTsix's Avatar
i hate uberdata, it always does stupid things like that to me, try using chrome, never had a problem with it
Old 06-24-2005, 09:26 AM
blackeg's Avatar
Default Re: installed 550's, now running way to lean??..... (onePOINTsix)
ok, more issues. got a new burner and it works fine (im using it on a friend's car also). i just cant get my car to idle- or i should say my air fuel at idle is like 60:1. i added 30% back into my fuel map at idle, and it didnt change the a/f. **** sometimes it just reads % o2 at idle.
i am leaning toward the resistors being bad. i think im gonna go pick up new ones and solder them in and see how it works. anyone have other suggestions. i have to dyno on monday or i wont be able to for the rest of the summer
Old 06-24-2005, 09:34 AM
dustin's Avatar
are you changing the right map? (high/low cam)
Old 06-24-2005, 11:53 AM
blackeg's Avatar
yea its an ls, so im doing low fuel and low ignition for my maps. i got new resistors, im gonna throw them in soon and see if it helps
DispicableB
03-29-2012 12:29 PM
pcguy760
02-28-2012 10:07 AM
pcguy760
07-23-2011 06:37 PM
AllMotorDA9
22
03-07-2005 11:17 AM
CRX-Freak
03-03-2003 08:34 PM
Quick Reply: installed 550's, now running way to lean??.....
