Inspect my oil return line angle please
Here's a mockup of the angle of my turbo and oil return line coming from it. It comes out toward the front of the car at about a 45 degree angle.....
Will this be OK?
Thanks in advance
Modified by whiteblurr at 5:21 PM 2/5/2004
Modified by whiteblurr at 5:31 PM 2/5/2004
Will this be OK?
Thanks in advance
the fitting of the turbo needs to point down to the pan. its hard to tell since the pics are so BIG! Also what is that crap you got around the line? if thats plastic crap you use to wrap audio wire, take that crap off...its just going to melt
i dunno... might just be the pics, but it almost looks like you can turn both the fittings a little inward and have a straight shot from turbo to pan.. know what i mean?
or is that just the pics?
the way i have been told is get your turbo center section straight up and down and then slope all the way down to oil pan and put the oil fitting as high as u can on the oil pan and u should be fine just make sure u use all SS stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteblurr »</TD></TR><TR><TD CLASS="quote">If I point the fittings towards each other, there is less than 2 inches between them
less than 2? but can you make it work? if you can thats your best bet, you might have to cut some line, i looks like you can make it work.
</TD></TR></TABLE>less than 2? but can you make it work? if you can thats your best bet, you might have to cut some line, i looks like you can make it work.
FOrSfEd
Feb 1, 2004 04:33 PM
