inquiry for h22 turbo
Old Jul 20, 2006 | 09:00 PM
jdmludeturbo's Avatar
Default inquiry for h22 turbo
I was curious to see if it was normal for the wastegate to be blowing air out of it while the car is idling, it runs good but feels like theres more turbo lag then normal but at top end it is very responsive.
Old Jul 20, 2006 | 10:05 PM
purpleh22's Avatar
Default Re: inquiry for h22 turbo (jdmludeturbo)
Not normal. Sounds like the turbo has enough capacity to over power the leak on the upper end. Wastegate valve stuck or some corrosion, foreign matter preventing a good seal?
Old Jul 21, 2006 | 12:03 AM
the seal is perfect between the wastegate and exhaust manifold but air for some reason is coming out the blow down tube its like i have two exhaust systems
Old Jul 21, 2006 | 12:32 AM
b00sted_hatch's Avatar
Little Hercules
Default Re: (jdmludeturbo)
Maybe you have a ULTRA ULTRA RARE TYPE R .5 PSI W/G SPRING.. That's what I would check..
Old Jul 21, 2006 | 07:41 AM
purpleh22's Avatar
Default Re: (b00sted_hatch)
Or internally, the wastegate is not sealing/closing properly.
Old Jul 21, 2006 | 10:07 AM
so if the wastegate is leaking air should i get a new one or is it okay to run the car this way. i don't feel much loss of power but feels a little slugish out of low rpms.
keving85
Mar 5, 2009 12:12 PM
EK FLY
Jul 8, 2006 06:26 AM
DETurbine
Jan 27, 2005 02:19 PM
XDEep
Mar 17, 2003 10:26 AM
