innovative wideband troubles
trying to figure this out. seems like im getting some weird reading
every ground is run to the thermostat ground. and every wire has been checked.
both analog 1 and 2 set to 0v-7.35 and 5v-22.39 for use with wide band gauge and hondata
hondata is not wired currently
video of analog outputs on the test gauge. my gauge installed in-car is reading weird dont know why
notice analog 1 reads perfect but analog 2 reads lean. i dont know why.
heres a video of my gauge in-car. it reads off while plugged into analog 1 which on the test gauge reads perfect
so is both the lc1 and my gauge screwed up
Re: innovative wideband troubles
Are you sure that you have both analog 1 and 2 set to 0v-7.35 and 5v-22.39? Where are you pulling power from? Do you have any other electronics in your car also grounded to the thermostat housing?
only things i ground the the thermostat are things that are related to engine. like the wideband and gauge.
the problem with the lc1 has been fixed thought i got a used one and plugged it in and recalibrate an works perfect. all numbers match perfect with hondata.
and problems with lc1 has since been fixed. replaced lc1
checked outputs with the test gauge and they are 100% matching with logwerks.
hoked up to hondata and numbers match 100% hook wideband up to gauge and the numbers are lean. so im going to go ahead and come to the conclusion gauge is ****ed
thankyou both for the help appreciate it
