InlinePRO kit, Stock Integra, AC, half radiator needed?
Old Jan 5, 2009 | 12:31 PM
nytosc's Avatar
From: New York in the summer, South Carolina in the winter
Default InlinePRO kit, Stock Integra, AC, half radiator needed?
Just curious, with a inlinePRO manifold, do I need to switch to a half radiator when keeping AC, or can I just use a slim fan? Has anyone done this?
I know with the greddy its not needed-
thanks!
Old Jan 6, 2009 | 02:29 PM
nytosc's Avatar
Default Re: InlinePRO kit, Stock Integra, AC, half radiator needed?
Any help would be strongly appreciated-
Old Jan 6, 2009 | 02:41 PM
SD_Lurker's Avatar
HT White Ops
you will be fine. The problem occurs when using ramhorns or similar manifolds where the gate is facing forward. AC friendly ramhorns are fine being that the gate location is kicked off to the side.
EDIT:You will still need a slim fan.
Old Jan 6, 2009 | 03:05 PM
kranky81's Avatar
I have the inlinepro on mine and i needed the slim fans. + the ac fan needs to be put on the other side pushing not pullin. Depending on the turbo size, u might have to shave your block, but just a lil bit, not a big deal. The half size rad is just to help with overheating issues tat all hondas get, with a big *** fan... all in all its good to get one i guess, bc hondas bays are so cramped that your IC might block the air flow to your rad.
Old Jan 6, 2009 | 03:14 PM
nytosc's Avatar
Good info! So the AC fan goes on the other side and I switch the wires? I think what I am going to do maybe is do 2 14" slim fans, and then get a greddy cooling plate as I have heard great things about them, along with some water wetter- I should be good to go. My last setup was 100% OEM cooling system from a EG that had a b20 turbo in it with no problems ever. I should be good to go i think
thanks for the info!
Old Jan 6, 2009 | 05:04 PM
kranky81's Avatar
yea, switch the wires, just make sure the fan is pushing. Dont have the greddy plate but sounds cool. i put heat wrap on the dumptube/downpipe. The dumptube bc its the closest to the rad.
Old Jan 6, 2009 | 05:08 PM
nytosc's Avatar
Yes, everything would be getting thermal coated, and the downpipe/ dumptube heat wrapped. This is a DD and needs to be 100% reliable.
any more input guys?
Old Jan 6, 2009 | 08:33 PM
EARLdaSQUIRREL's Avatar
official honda whore
ya, quit posting stupid questions and just do it
Old Jan 7, 2009 | 06:52 AM
nytosc's Avatar
thanks bud lol
hows your LS coming along?
Old Jan 7, 2009 | 09:53 AM
its being swapped back to a stock motor and sold and then a secret project will be started
Powerboss
Feb 20, 2014 11:39 AM
cn_bb
Aug 9, 2012 11:00 AM
stefanne3
Jul 17, 2007 08:37 PM
jazz215
Aug 23, 2003 10:48 PM
