injectors question with the drag kit
Hi, I just installed my drag gen 3 kit on my 2000 si. I was going with the hondata 2b with the 440 injectors but my local dyno is closed because they are moving...Anyway I did installed the 440(without hondata) but and when I started the car It was running rich as hell...So what can I do now because I need my car running now! Is there a way I can stay with the 440 without hondata(I have no vafc) or I have to go back to my stock injectors?And how much boost my stock injectors can hold without beeing lean with the drag kit? I did a 45min. search and no luck.....please drop a quick reply if you know something...
Do you have an fmu or anything? You guys are telling him to run on 6-7 lbs with no fuel management whatsoever. I dont think it is a good idea to boost at all without some sort of boost dependent device. Am I wrong here.
I dont think you should run your stock injectors past 8 psi, that is what I was told by my local performance shop anyway, past 8 on stock injectors in pushing it plus the drag fmu is tuned for 7psi, correct me if I'm wrong..
he has a drag kit...hense he should have a 12:1 fmu and an airtex inline pump.
a set up I know to be fine for at least 8.5-9psi.
I have the complete drag kit including the 12:1 fmu. I decided to take the bus until I get the hondata installed.
You guys realy helped me decide what to do.!!!Thanks a lot people.!!
