Injector's Question
Old Sep 18, 2007 | 08:07 AM
u n v kenny's Avatar
Default Injector's Question
What is an ideal injector size to get for a stock '95 GSR motor with a Garrett 57trim turbo? They're stock right now.
I'm pushing 7lbs boost. 300? 680? 1000?
It has a Vortech FMU. Any other info you'd need to help me just let me know. Thanks in advance.
Old Sep 18, 2007 | 08:14 AM
92civicx's Avatar
Default Re: Injector's Question (u n v kenny)
its not how many pounds its how many horses. if your somewhere around 250 i would get some 440's.
Old Sep 18, 2007 | 08:17 AM
Default Re: Injector's Question (92civicx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicx &raquo;</TD></TR><TR><TD CLASS="quote">its not how many pounds its how many horses. if your somewhere around 250 i would get some 440's.</TD></TR></TABLE>
Well I haven't dyno'd it. It's in the shop getting the driver side intercooler piping finished, and the 3" mandrel bent exhaust welded. It will be tuned with s300 shortly after. It has a/c and i'm hoping for 280+ or so people have told me...
bigbadboy's Avatar
get some 750's and ditch the FMU. then u have injectors with room to grow if you want more power later on down the road.
Old Sep 18, 2007 | 08:20 AM
Default Re: (bigbadboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">get some 750's and ditch the FMU. then u have injectors with room to grow if you want more power later on down the road.</TD></TR></TABLE>
Thank you.
Old Sep 18, 2007 | 08:22 AM
Schister66's Avatar
Man U FTW
7psi and an FMU...you're not hitting 280whp unless you're on a Dynopack.
Ditch that POS FMU and get a real EMS. Then snag some 550cc injectors and a boost controller. Tune on 10-11psi (or whatever the stock map will handle) and have fun.
Old Sep 18, 2007 | 08:27 AM
bigbadboy's Avatar
Default Re: (Schister66)
please read before you post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u n v kenny &raquo;</TD></TR><TR><TD CLASS="quote">
It will be tuned with s300 shortly after </TD></TR></TABLE>
Old Sep 18, 2007 | 08:35 AM
Thanks guys, especially bigbadboy.
I don't want to up the boost anymore as it's a daily driver. Maybe in the long run if I need to rebuild my bottom end. I do have a voodoo manual boost controller however. It may see 9lbs one day.
Old Sep 18, 2007 | 09:17 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u n v kenny &raquo;</TD></TR><TR><TD CLASS="quote">I don't want to up the boost anymore as it's a daily driver. Maybe in the long run if I need to rebuild my bottom end. I do have a voodoo manual boost controller however. It may see 9lbs one day.</TD></TR></TABLE>
I drive my GSR daily on a turbo approximately the same size as a 57 trim. I run it at about 10.8psi without any problems. All summer at 315whp w/ no problems....last summer at 275whp and again no problems. With a good tune, you'd be surprised what kind of abuse a stock GSR can handle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">please read before you post.
my bad
Old Sep 18, 2007 | 09:51 AM
92civicx's Avatar
Default Re: (u n v kenny)
310cc - 55 HP per injector -
440cc - 77 HP per injector -
525cc - 85 HP per injector -
680cc - 120 HP per injector -
780cc - 135 HP per injector -
880cc - 151 HP per injector -
1000cc - 171 HP per injector -
1600cc - 275 HP per injector -
Old Sep 18, 2007 | 10:12 AM
Default Re: (92civicx)
Thanks 92civic! Appreciated!!
Old Sep 19, 2007 | 10:47 AM
bigbadboy's Avatar
just remember those are estimates. everything depends on set up and the efficiency of your motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u n v kenny &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys, especially bigbadboy.
haha you may say u'll almost never hit 9 but i know in like a week or 2 of boosting your going to set it at 9 for DD 9 will be perfectly fine for a DD. i started off with 4psi on my LS DD and my high was 10 but that quickly changed lol. now i'm at 15 psi DD on an stock LS street tuned by me. get tuned for 15 that way when you decided to turn it up you won't have to re-tune. boost is fun and addicting so welcome to the club
Old Sep 19, 2007 | 12:44 PM
Thanks, here's my old setup.
khmboostedeh2
Mar 25, 2005 11:48 AM
boostedlude3g
May 26, 2004 01:43 AM
2ltrsnailpwr
May 3, 2003 08:40 PM
hybridb18
Oct 7, 2002 10:04 PM
PROFILES2000
Oct 1, 2001 01:06 PM
