Injectors are bigger. will they work?
Old Oct 22, 2006 | 01:53 PM
aaroboost's Avatar
Default Injectors are bigger. will they work?
Ok so im putting in my turbo stuff into my ls this weekend, and I get around to the injectors.
they are 460 cc injectors, from an rx7. they are phsyically a different size than stock. they are longer, and fatter. If a dremel out the sealer rings, is it ok if the injector sticks farther into the intake manifold than stock? I dont really see another way to do this.
thanks.
Old Oct 22, 2006 | 04:00 PM
aaroboost's Avatar
Default Re: Injectors are bigger. will they work? (aaroboost)
anyone?
Old Oct 22, 2006 | 04:27 PM
2point2's Avatar
Thats a good question, here's a shitty answer:
If you read enough 'injector install' threads you'll notice that people are installing injectors a few different ways. The way I installed my precision ones makes them go deeper into the intake manifold; everything works fine. I think I have a pic if you want..
You can probably figure out a way to shim them if they 'look' like they're too far into the manifold... a spare intake manifold would could help you come up with something.
What style are RX7 injectors?
Old Oct 23, 2006 | 05:58 AM
aaroboost's Avatar
What do you mean by what style? I know i have to wire in the resistors. I also dont have a spare intake manifold, but i guess ill just rig it to work. as long as theres a good seal i think it willl be fine.
Chris_Spires
Mar 15, 2009 06:39 PM
DaveF
May 20, 2004 11:41 AM
xtal
Sep 17, 2003 03:46 PM
austrian type-R
Oct 3, 2002 09:43 AM
dustin
Feb 25, 2002 04:34 AM
