Injectors bad
Old Sep 4, 2007 | 06:42 PM
Jdmsolutions's Avatar
Default Injectors bad??????????
(keep in mind i had these injectors rebuilt and flow tested) alright guys im stumped.... if anyone can help. setup: built ls stock cr t/4 dsm blue tops, ok the tune i had was pretty on to begin with. would run pretty decent until about 5k then load up down to around 10.3..(i know thats shity but beside the point) ok so the other night i just took off hard in my car from first and when i pulled into second the car shot pig rich and has been stuck that way every sense... any ideas? even at idle its lopey idle and staying around 10.0 on the wideband... any amount of throttle takes it up to arond 12.0 then goes right back to 10.0 when i get to part throttle again.
Old Sep 4, 2007 | 07:11 PM
xenocron's Avatar
Default Re: Injectors bad?????????? (Jdmsolutions)
blew out your map sensor perhaps or one of the vacuum lines tee'd into the map sensor?
Old Sep 4, 2007 | 07:42 PM
Default Re: Injectors bad?????????? (xenocron)
haha yeah i feel pretty dumb.. you were right. i got a another qusetion if you have time. i got my chip from phearable and it isnt as close as i would like it. its runs down to around 10.3 at wot. and my chip reader isnt capable of opening it. is there a certain procedure?
Old Sep 4, 2007 | 08:24 PM
xenocron's Avatar
what chip and what chip reader?
most likely you just have to set the offsets correctly and be reading the appropriate chip in your burner software
Old Sep 4, 2007 | 09:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">what chip and what chip reader?
most likely you just have to set the offsets correctly and be reading the appropriate chip in your burner software</TD></TR></TABLE>
ya know i have no clue on this stuff.. i know the reader is a memorex one. and the chip is a 28 pin from vega on crome
Old Sep 5, 2007 | 05:00 AM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmsolutions &raquo;</TD></TR><TR><TD CLASS="quote">
ya know i have no clue on this stuff.. i know the reader is a memorex one. and the chip is a 28 pin from vega on crome</TD></TR></TABLE>
Time to buy a BURN1
Memorex? Dont they make cassette tapes?
Old Sep 5, 2007 | 09:53 AM
haha yeah they make cdrws from walmart too lol....
Old Sep 5, 2007 | 09:54 AM
do you burn chips for people?
pcguy760
Jul 23, 2011 06:37 PM
eflove
Oct 10, 2004 05:13 AM
420aNT
Apr 8, 2003 08:11 PM
schwett
Jun 19, 2002 01:21 PM
