Injectors
Old Apr 12, 2006 | 03:00 PM
EJ8 GSR-T's Avatar
Default Injectors
What size would everyone reccomend for a built GSr with a t3/t4 60 trim?
Old Apr 12, 2006 | 03:05 PM
Adriano's Avatar
Default Re: Injectors (userdead626)
If you have a good engine management, I would just some 880 or 1000cc's. This way you have some room down the road
Adriano
Old Apr 12, 2006 | 03:50 PM
RogueWorks's Avatar
Default Re: Injectors (Adriano)
well, first you should let us know what hp you plan on attaining.
Old Apr 12, 2006 | 03:57 PM
Mugencrxsir1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Adriano &raquo;</TD></TR><TR><TD CLASS="quote">If you have a good engine management, I would just some 880 or 1000cc's. This way you have some room down the road
Adriano</TD></TR></TABLE>
I'm running 880cc with about the same sized turbo, on my lsvtec.
Old Apr 12, 2006 | 04:09 PM
skratchnsnift's Avatar
http://www.rceng.com/technical.htm
Old Apr 12, 2006 | 05:28 PM
EJ8 GSR-T's Avatar
Default Re: (skratchnsnift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skratchnsnift &raquo;</TD></TR><TR><TD CLASS="quote">http://www.rceng.com/technical.htm</TD></TR></TABLE>
yeah i allready had done the math, it said thaat about 550cc is enough, but everyone has told me different....i have no idea what kinda hp this setup will make becuase its not complete....what do you guys think? keep in mind its stock sleeves, and it will be somewhat tuned down because its my daily and i need it to last a while
Old Apr 12, 2006 | 09:10 PM
RogueWorks's Avatar
Default Re: (userdead626)
You will probably be running it under 300whp by what you describe. 550cc will be fine, there is no need to throw 1000cc injectors in there.
Old Apr 12, 2006 | 11:22 PM
Dstretch33's Avatar
Default Re: (RogueWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RogueWorks &raquo;</TD></TR><TR><TD CLASS="quote">You will probably be running it under 300whp by what you describe. 550cc will be fine, there is no need to throw 1000cc injectors in there.</TD></TR></TABLE>
exactly the injectors are rated by hp, so if u not making huge #'s 1000cc's would be overkill
Old Apr 12, 2006 | 11:23 PM
adictionbass's Avatar
Default Re: (Dstretch33)
550s or 750s would leave you plenty of room to grow.
Old Apr 13, 2006 | 03:28 AM
EJ8 GSR-T's Avatar
Default Re: (adictionbass)
under 300? on a built motor haha na, i have put to much into it to run it under 300, but probably keep it at abbout 350, so for 350hp with a little room to grow what you would say? 750's?
RevTek 6
Dec 25, 2006 11:48 AM
CaptainMorgan
Dec 27, 2005 06:09 PM
ineedboostbad
Sep 17, 2005 08:17 AM
slowtealgsx
Oct 19, 2003 02:06 AM
