Injector wiring help
Old Mar 10, 2004 | 10:38 AM
SPOOLINTEG's Avatar
Default Injector wiring help
I am using an aftermarket injector from SFP they are 55cc injectors.
what size Resistor do I use to make them work on my car it is OBD-1
-the aftermarket injectors read at 3 ohms
-the factory injectors reat at 12 ohms
so would that mean I would used a 8ohm resistor or is there another way to do this?
if that is all I need to do is wire in a resistor then that is all I need to so then right?
thank you
Old Mar 10, 2004 | 10:40 AM
b18bturbo's Avatar
Default Re: Injector wiring help (SPOOLINTEG)
you have two choices
you can wire resistors inline usually what most guys use is 10wat 10ohm resistor from radio shak inline to the yellow wire
and
you also have the choice of wiring a resistor box. please do search here on honda-tech and you will find alot of more information
Modified by b18bturbo at 3:46 PM 3/10/2004
BlownBlackSi
Sep 30, 2006 01:28 PM
80884
Oct 23, 2005 01:12 PM
jeezerb18c
Sep 2, 2005 08:49 PM
berettagtz117
May 1, 2004 10:40 PM
