DPFI To MPFI swap need help!!!
Old May 1, 2004 | 08:26 PM
berettagtz117's Avatar
Default DPFI To MPFI swap need help!!!
Ok were are about done wiring up everything for MPFI but we are using obd1 harness and injectors w/ Z6 mani.. I have been trying to find a site where they show how to wire up the injectors w/out the resistor box just going straight to injectors because they are not obd0 so no resis box needed.. Can anyone help me or give me a sight where to find out?? thanks Kyle
Old May 1, 2004 | 08:34 PM
onePOINTsix's Avatar
Default Re: DPFI To MPFI swap need help!!! (berettagtz117)
well i dont know the pinout but if you take the wire that would power the resistor box and run it to all the injectors with the other wire on the injectors going to the ecu it should work. if that confused you:
Old May 1, 2004 | 10:40 PM
distortionwarrior's Avatar
Default Re: DPFI To MPFI swap need help!!! (Sideout)
no, that wasnt confusing at all....
i think what he was (maybe) trying to say is that each injector has
(A) 1 wire coming from the ecu in a direct mannor
(B) that each injector has their own wire coming from the resistor
(C) mspaint sucks
if your injectors are high impedance and dont need the resistor then they can run in parrallel with eachother from a common power source such as the yellow/black wire that used to run either your resistor or go straight to your injectors.
if it seems a bit odd that you can run them all in parrallel, test me out: take a multimeter and do a resistance check between the common colored wires going to the injectors in your oem setup. ill bet you a dollar that they are going to be litle to no resistance and they are just a factory splice job.
Orangevirus1
Jul 9, 2013 07:55 AM
jdmdikk
May 8, 2009 06:50 PM
Jonathan_ED3
Mar 18, 2008 09:04 PM
jadugartir
Feb 23, 2005 03:05 PM
hybridturtle
Nov 1, 2004 08:32 PM
