Injector Source: Not your typical request...
Old Jan 4, 2008 | 09:01 AM
  #51
jDMJeRk's Avatar
<--- Worried... I need 16 injectors. DFI EFI Methanol.
Old Jan 6, 2008 | 02:07 PM
  #52
sander's Avatar
2.7(p/t)
Default Re: (jDMJeRk)
Hmm, I saw it listed on their site a while ago. Sorry for the false info.
Old Jan 6, 2008 | 06:59 PM
  #53
Jared's Avatar
if these are so readily available, why are so many race cars running 2 and 3 injectors per hole?
Old Jan 7, 2008 | 05:42 AM
  #54
tony1's Avatar
Default Re: (Jared)
For one, these super big injectors (350lb+) only came about fairly recently. Two, you're MUCH better off with 2 160lb injectors than one 320lb injector. Just like 1600's run like crap compared to 550's, the spray pattern on the big injectors is so bad that you end up using WAY more fuel than you really need because most of it doesn't atomize and burn. You don't want liquid fuel in your cylinder. The big injectors are like water hoses rather than spray bottles.
Motec used to carry 280lb injectors that were designed for propane. They didn't work good at all on anything but propane because there was such a shitty "spray" pattern. They quit carrying them because they just didn't work right, they have 6 left if anyone wants them. lol
The best way to do it is with as many 160lb injectors as it takes to meet your power goals.
Edit: this post is referring to the 280lb injectors that Motec sells. I've never used the bigger ones but i've been told by a very reliable source that they don't have the issues that the ones Motec sold. They have a very good spray pattern and work very well.
Modified by tony1 at 7:28 PM 1/7/2008
Old Jan 7, 2008 | 08:19 PM
  #55
Jared's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">For one, these super big injectors (350lb+) only came about fairly recently. Two, you're MUCH better off with 2 160lb injectors than one 320lb injector. Just like 1600's run like crap compared to 550's, the spray pattern on the big injectors is so bad that you end up using WAY more fuel than you really need because most of it doesn't atomize and burn. You don't want liquid fuel in your cylinder. The big injectors are like water hoses rather than spray bottles.
Modified by tony1 at 7:28 PM 1/7/2008</TD></TR></TABLE>
good info. next meth car i do may bet one injector per hole. thanks tony.
Old Jan 20, 2008 | 05:43 PM
  #56
jDMJeRk's Avatar
Default Re: (tony1)
Spray pattern makes all the difference... We ended up going with 160lb injectors... We'll see how the dyno turns out next month... I'll post results then
CHB
K Series
Oct 19, 2017 12:23 AM
wantboost
Aug 21, 2012 07:11 AM
Bobalobagis
Jun 2, 2012 05:29 AM
valleyhatch
Mar 27, 2008 01:26 PM
Boilermaker1
Mar 18, 2007 08:29 PM
