Injector Sizing for Nitrous
Old May 8, 2016 | 04:24 PM
43!'s Avatar
43!
Default Injector Sizing for Nitrous
Hi, I have a b20v and NA makes about 250-260whp on pump E85. I want to add a 100-150 direct injection dry hit of nitrous to the mix with S300.
I'm currently on 725cc ID with a Walbro 255. Can somone recommend what size ID I should move up to? What about fuel delivery? In tank pump if I have to change would be preferred.
Thanks.
Old May 8, 2016 | 10:21 PM
96ekb20's Avatar
Default Re: Injector Sizing for Nitrous
i always like using a 450 off the bat. mite beable to use your injectors with uping the pump to a 450 depending on how much base fuel psi you have and what duty cycle your at.
Old May 10, 2016 | 08:40 PM
motoxxxman's Avatar
if the walbro 255 is a genuine walbro (there's lots of knockoffs out there), it should be able to support up to 400hp no problem.
as said above, those injectors should be capable with a bump in base pressure. I'd say 50psi base pressure should do the trick, though it will obviously require a full re-tuning of the fuel maps. a global fuel change will not suffice.
if you're set on changing injectors to make sure you're good, 1000's will definitely support your goals.
turbolsvtecej1
Sep 7, 2014 04:06 PM
Tylerjdmgsr
Jul 20, 2011 04:22 PM
turboman2.2
Nov 30, 2010 02:56 PM
kabaroo
Jul 9, 2004 11:06 PM
hondaeg8
Apr 2, 2004 04:40 PM
