Injector question E85
Hey building a LSvtec im going to be running E85 on it i need to know what injectors can I run with a resistor box for E85??? i know i need 1000cc or higher for E85 but I have a resistor box. Thanks for your time.
rc 1000's 1200's 1600's
precision 1600's(with an injector driver preferably)
Injector dynamics 1000 and 2000cc, no need for resistor box.
This isnt a hard issue.
No. It's on the contrary. If you're not using a resistor box then it limits the injectors you can use. Most high flowing injectors are low impedence(peak and hold) aka need a resistor. But I personally would not run the resistor and get the ID1000's they are amazing.
my power goal is 400whp on a LSvtec with ITR cams and a good turbo setup I got for it. I should beable to hit that on E85 prolly going to run 1000cc injectors was thinking RC injectors.
you dont need 1000's to reach that goal but you can get them..if your goal is only 400whp then im sure some 880's would be just fine for you... i made 440 whp on E85 with 880's, they were about maxxed out though
