Injector question E85
Hey building a LSvtec im going to be running E85 on it i need to know what injectors can I run with a resistor box for E85??? i know i need 1000cc or higher for E85 but I have a resistor box. Thanks for your time.
Re: Injector question E85
search.
rc 1000's 1200's 1600's
precision 1600's(with an injector driver preferably) Injector dynamics 1000 and 2000cc, no need for resistor box. This isnt a hard issue. |
ya i understand that i guess i was trying to ask that if using a resistor box would limit what injectors i could use for E85?.
No. It's on the contrary. If you're not using a resistor box then it limits the injectors you can use. Most high flowing injectors are low impedence(peak and hold) aka need a resistor. But I personally would not run the resistor and get the ID1000's they are amazing.
what is the power goal?
my power goal is 400whp on a LSvtec with ITR cams and a good turbo setup I got for it. I should beable to hit that on E85 prolly going to run 1000cc injectors was thinking RC injectors.
Originally Posted by CivSiClone_96
(Post 41007000)
