Injector question
Old Jan 10, 2005 | 08:47 AM
ncervantes's Avatar
Default Injector question
Will 450cc DSM injectors fit fine on my '95 SOHC 1.6L civic motor, or will I have to get RC injectors?
Old Jan 10, 2005 | 08:54 AM
MikeMAN's Avatar
Default Re: Injector question (ncervantes)
they will fit if you bore out the injector seals. The seals on your car will be a tad too small, but you can take them out and dremel them a bit.
mike
Old Jan 10, 2005 | 08:55 AM
Curtisbeef's Avatar
your gonna need a resistor box
Old Jan 10, 2005 | 08:58 AM
ncervantes's Avatar
Default Re: (Curtisbeef)
they are going into my 89 CRX, which I am going to turbo, why would I need a resistor box?
Old Jan 10, 2005 | 09:03 AM
Curtisbeef's Avatar
because DSM injectors are Peak and Hold...
Old Jan 10, 2005 | 09:10 AM
ncervantes's Avatar
oh, so if I go RC, then I won't need the resistor box and I won't need to modify anything?
Old Jan 10, 2005 | 09:13 AM
MikeMAN's Avatar
Default Re: (ncervantes)
depending on what engine harness you are using, CRX's come with resistor boxes...but since you swapped in another engine, chances are you dont have it anymore.
mike
Old Jan 10, 2005 | 09:17 AM
Curtisbeef's Avatar
If you get RC Saturatd injectors then you should be fine you may have to bore out the injector port a little with a dremel
Old Jan 10, 2005 | 09:18 AM
ncervantes's Avatar
Default Re: (MikeMAN)
I don't remember if I removed it when I swaped motors. I think it is still there, I don't know why I would have removed it? *shrug*
I think I may just go RC, I'd rather do the plug and play, even though it will cost me double.
Old Jan 10, 2005 | 11:15 AM
TunerToys's Avatar
Here is a link to one of our tech articles for measuring your injector inpedance.
http://stores.ebay.com/Tuner-T....html
Low Impedance = Peak and Hold = 2-4 Ohms = Need resistor box
or
High Impedance = Saturated = 10-12 Ohms = No need for resistor box
Hope that helps. You have IM.
Craig @ Tuner Toys
CivSiClone_96
Dec 20, 2009 05:52 PM
mortificationrock
Jun 10, 2007 09:05 PM
G0TB00ST
19
Apr 13, 2007 03:30 PM
Hoodwinked
Dec 13, 2003 12:33 PM
rbf351
Nov 2, 2002 10:05 PM
