Injector O-Ring tear :o
Old Oct 7, 2004 | 06:17 PM
m R g S r's Avatar
Default Injector O-Ring tear :o
I opened my hood tonight, and almost immidately after, fuel started spraying everywhere. I looked closer (after I turned the car off) and noticed that the O-Ring that fits into my AEM fuel rail was ripped and hanging out.
I had a vaccuum leak with my DSM 450cc's, because they weren't pushed down into the Injector seal on the intake manifold enough. I guess this did not leave enough injector in the fuel rail, because the fuel rail will bottom out against the intake manifold before clamping down hard on the injector.
I know that in some cases there are plastic "spacers" that go in between the intake manifold and the injector seal, but I don't recall my stock GSR having those. I also have a Venom Intake manifold.
Anyone know what the part # is for the injector spacer, or if it is even supposed to be there?
Thanks. .
Old Oct 7, 2004 | 08:03 PM
al3e's Avatar
Default Re: Injector O-Ring tear :o (m R g S r)
bump...i got a ripped injector o ring also im going to kragen or napa tomarrow tho see if they gots any..... i think all cars have the same size../ maybe i was hearing cheet
Old Oct 7, 2004 | 08:28 PM
LostSolVTEC's Avatar
Default Re: Injector O-Ring tear :o (al3e)
i tore the ones on the top of the injector on my RC's sent them an e-mail and they sent me out some more.
Old Oct 7, 2004 | 09:01 PM
J337_UNIT's Avatar
Default Re: Injector O-Ring tear :o (LostSolVTEC)
i tore the ones on the injectors going into the Fuel rail... I just went to a hardware shop and bought ones that were closest to the same size.. they work FINE.. no leaking at all.
Old Oct 8, 2004 | 08:03 AM
m R g S r's Avatar
Default Re: Injector O-Ring tear :o (J337_UNIT)
Yea, but my problem is because the injector itself does not sit far enough up into the fuel rail. I ordred some spacers from len, the ones that are meant for the LS intake manifold, they should be here tomorrow. I'll see how that works out. Jus sux I can't drive my car now. . .
Old Oct 12, 2004 | 08:17 PM
m R g S r's Avatar
Got the spacers, installed em and everything works alright, for now. . .
Old Oct 12, 2004 | 08:48 PM
J337_UNIT's Avatar
good luck
iwantspeed
Dec 22, 2007 01:04 PM
rwasmund
Feb 23, 2007 02:59 AM
Anti-Drama Queens
Apr 6, 2006 05:20 AM
Louie_EM1
12
Feb 29, 2004 09:34 AM
lowboost civ
Apr 22, 2003 08:47 AM
