Injector install
I searched but wasnt too sure about the answer. This is what i came up with, can someone tell me if its correct. If your car is OBD2 all you need to do is clip in the injectors and they just plug in. If your car is obd1 you need to wire them in? My cars obd2, so would i just install them regularly without splicing?
Its very simply and not a big deal, you could prob find the injector clips for about $20, then just splice and SODDER them in.
Check out how i did it. I left the stock clips on there so I can just swap the stock injectors back in if I ever need to.
The stock one is on the top, and you can see I just spliced the black wires in.
Very basic install, but do it the right way and SODDER the connections!!
I was looking for something like Rc's. But i thought I could just plug them into the stock clip. But it seems pretty easy, so i might just use DSM injectors. Thanks for the info guys
I just posted this in another thread recently but i can't find it.
CPR http://www.sensarium.com part #6002021 is the plug and play obd2=>obd1 injector conversion harness
but they're about $22 each
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR99 »</TD></TR><TR><TD CLASS="quote">I was looking for something like Rc's. But i thought I could just plug them into the stock clip. But it seems pretty easy, so i might just use DSM injectors. Thanks for the info guys
either way DSM, RC, you still need an obd1 clip.
</TD></TR></TABLE>either way DSM, RC, you still need an obd1 clip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toda Party »</TD></TR><TR><TD CLASS="quote">either way DSM, RC, you still need an obd1 clip. </TD></TR></TABLE>
yup most aftermarket injectors are gunna fit obd1 clips not obd2
Black R
Jun 17, 2004 01:34 AM
