Initial start-up and high temp.??? help
Old Aug 6, 2006 | 07:48 AM
dkboyny11's Avatar
Default Initial start-up and high temp.??? help
I just started my benson sleeved and built B16 and ran it for the 10 min. that was recommended. I noticed when I went to shut it off that the temo was way high. I added coolant to the system but didn't bleed it yet, plus a new water pump, and thermostat. What could this be caused by??? Thanks for any help
Old Aug 6, 2006 | 07:56 PM
B18 CYA's Avatar
was your fan turning on?
Old Aug 6, 2006 | 08:07 PM
dunkd's Avatar
air bubbles in the coolant, gotta bleed that thing at first.
Old Aug 7, 2006 | 09:25 AM
dkboyny11's Avatar
Default Re: (B18 CYA)
Going to bleed the system and ya, for some reason the fan didn't kick on either. I'll have to look into both of those.
Old Aug 7, 2006 | 09:30 AM
Boostage's Avatar
make sure the thermostat is opening
Old Aug 7, 2006 | 09:38 AM
86si's Avatar
Default Re: (dkboyny11)
if there is alot of air in the system the fan will not kick on even if the gauge is reading high.
Old Aug 7, 2006 | 10:28 AM
dkboyny11's Avatar
Default Re: (86si)
Thanks for the update on the fan. I did on the other hand find out that I forgot to wire in the water temp sender to the car, not just the autometer gauge. Oops. I fixed the problem. All I need now is to change the oil and wait for Sept. 29th for my tune date. on your build 86si. I don't if you remember me from when JDogg did the tune on your buddies motor you built. I can't wait to see what this new benson bottom end and p&p does for my set-up.
MrBigMac
Honda Civic (2001 - 2005)
May 15, 2016 04:25 PM
84dime
Sep 16, 2009 04:02 PM
bumthology
11
Dec 11, 2004 11:23 AM
S@nt0s
12
Feb 25, 2004 05:16 PM
ED8DX
11
Sep 2, 2002 12:58 PM
