Info/Opinions on Inline Pro Headgasket...
Old Feb 24, 2003 | 09:54 AM
01ITR#700's Avatar
Default Info/Opinions on Inline Pro Headgasket...
I did a search but woulf like any and all info. and experience with their headgaskets.
My quest to keep my Turbo ITR internally stock is over unfortuantely I blew the headgasket and/or bent a valve. So for the time being I'm getting the head checked out and was thinking I might as well throw in one of the Inline Pro headgaskets as well. I wanted to know if anything else needs to be done at the same time? Are cam gears needed? Should I put in a block guard too since the head is off?
Thanks for any info.
M
Old Feb 24, 2003 | 10:39 AM
jinxproof99's Avatar
New User
Default Re: Info/Opinions on Inline Pro Headgasket... (01ITR#700)
you will need cam gears. i wouldn't do the blockgaurd. you will be able to run at least 10 lbs of boost on 93 octane with 440 injectors(or bigger) and proper management/tuning. the inlinepro headgasket is definitely a good choice for stock type r's and boost.
Old Feb 24, 2003 | 10:47 AM
PM-Performance's Avatar
Default Re: Info/Opinions on Inline Pro Headgasket... (jinxproof99)
nline pro stuff.
yea you wil need to adjust the cam gears whenever changing compression like that
Old Feb 24, 2003 | 11:00 AM
boostin b16's Avatar
Default Re: Info/Opinions on Inline Pro Headgasket... (itr206)
i have had one on my car for almost a year now and have been compleatly content with it!! my car has seen as high as 1.4 bar and is run at 1.0 bar daily with out a problem. I personally would recommend cam gears, a block guard, 370CC+ injectors, and good tuning. I am not a huge fan of inline pro, but i for one have had a great experience with there head gasket!
Old Feb 24, 2003 | 11:03 AM
gSr_jB's Avatar
Default Re: Info/Opinions on Inline Pro Headgasket... (MY"little"T3)
Speaking of cam gears and compression.
I just got my bottem end rebuilt wiht Arias 9:1cr and I don't have aftermarket cam gears.
So would you guys suggest I get some? whenver messing with the compression you need to adjust the cam gears?
Old Feb 24, 2003 | 11:05 AM
Default Re: Info/Opinions on Inline Pro Headgasket... (gSr_jB)
yea you have to . wheneever changing compression like that you have to adjust the timing to equal it out oper say . . . i think if you dont you risk detonationor sometihng .
i never dealt with it 1st hand , but know frm talking to the guys from inline and some other people when i was gonna change my compression
Old Feb 24, 2003 | 11:10 AM
gSr_jB's Avatar
Funny..I wonder why they didn't say anything to me..My car is sitting at inline right now..lol. I went from 10:1 to 9:1 on the jrsc and well i guess I'll have to get a set of cam gears as well.
Old Feb 24, 2003 | 11:29 AM
92JDMSiR's Avatar
I don't think you need cam gears if you are lowering the compression with pistons. if your lowering the compression with a thicker headgasket you need cam gears.
Old Feb 24, 2003 | 11:34 AM
Default Re: Info/Opinions on Inline Pro Headgasket... (92JDMSiR)
either way the compresion is changing, correct me if im wrong , but as long as the compression chages you would need to tune out the difference.
esp with that kinda change.
Old Feb 24, 2003 | 11:37 AM
New User
when using an inlinepro headgasket you have to use cam gears due to a fitment issue, not a compression issue.
instant message inlinepro or email them. they will explain it to you.
[Modified by jinxproof99, 3:38 PM 2/24/2003]
Old Feb 24, 2003 | 11:42 AM
mos's Avatar
mos
I think the reason you should use cam gears is that you are changing your deck height. Whenever you lower your deck height by machining the block or head, or raise it by using a thick headgasket, you throw off the cam timing a little bit. It doesn't have anything to do with compression.
Old Feb 24, 2003 | 11:53 AM
Default Re: Info/Opinions on Inline Pro Headgasket... (mos)
ok that makes sense with the dek height then .
whe i talked to thme they told me to use thme becuase of the compression changes?
i dunno maybe i msunderstood them .
Old Feb 24, 2003 | 12:02 PM
Call the Jon at inline and he will explain it to you. it has nothing to do with compression ... but it has to do with the cam timing being slightly off because of the change in deck height though!
96B16civic
Jun 15, 2009 10:02 PM
dohcdelsol
Jun 7, 2006 12:42 PM
DJ Gurgla GSR
Nov 15, 2005 09:14 AM
NewtoHonda
Jul 24, 2005 02:27 PM
blundar
Oct 28, 2004 01:06 PM
