im thinking turbo!
Old Jul 13, 2007 | 09:59 PM
ghostcivic's Avatar
Default im thinking turbo!
ok i have a 92 civic with a b18b1.i want to turbo it.i only want to run 7-10 lbs of boost. question 1 is will a turbo hurt stock internals with 125,000 miles on it?my second question is if there is a likely chance that is can then what should i up grade in my motor? thanks
Old Jul 13, 2007 | 11:00 PM
krazyhmongboi's Avatar
try doing a compression test and low boost should b ok with stock internals
Old Jul 13, 2007 | 11:53 PM
Doostur's Avatar
I have seen people run 8-10 pounds all day long on stock internals with no problems at all with an LS. Even had a few friends run 12 pounds with no problems but thats where your pushing your luck. I personally wouldn't go over 10.
Old Jul 14, 2007 | 09:28 AM
ghostcivic's Avatar
Default Re: (Doostur)
sweet! thats good to know. anybody know the best for the price.and where i should look for a turbo.as you can tell im new to the whole turbo thing.but i need more speed.07 eclipse beat me with the 3.8l and i cant have that.so im just trying to get some info.anything else i should know? thanks everybody for ur help.
Old Jul 14, 2007 | 09:38 AM
ej8's Avatar
ej8
Default Re: (ghostcivic)
It's all in the tuning. Tune the fuel rich, take out more than enough timing and ALWAYS use premium fuel - and don't get crappy water gas or the 10% ethanol crap. And don't use a freaking FMU.
Do LOTS AND LOTS of reading before you attempt to do anything at all, and get a buddy to help you that has done it before and it will make your life much easier.
I run 8psi daily, but wouldn't sweat running 12psi on my car because I know how to tune. Also, boost pressure isn't everything because not every turbo makes the same power at the same pressure level. READ READ READ is the best advice you can be given.
The end result is VERY rewarding, and you can never turn away from the darkside as it is a never-ending addiction
Old Jul 14, 2007 | 10:23 AM
bnut510's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">I have seen people run 8-10 pounds all day long on stock internals with no problems at all with an LS. Even had a few friends run 12 pounds with no problems but thats where your pushing your luck. I personally wouldn't go over 10.</TD></TR></TABLE>
hp, not psi bruhh
Old Jul 14, 2007 | 07:25 PM
ghostcivic's Avatar
Default Re: im thinking turbo! (ghostcivic)
thanks thats good info. anybody know where to look for one.im not going on ebay i dont trust that ****.
Old Jul 15, 2007 | 12:29 PM
TehGhett0P1mp's Avatar
Default Re: (ej8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej8 &raquo;</TD></TR><TR><TD CLASS="quote">It's all in the tuning. Tune the fuel rich, take out more than enough timing and ALWAYS use premium fuel - and don't get crappy water gas or the 10% ethanol crap. And don't use a freaking FMU.
The end result is VERY rewarding, and you can never turn away from the darkside as it is a never-ending addiction </TD></TR></TABLE>
HP people not PSI... One PSI on a turbo is completely different on another one..
To answer the OP you should be fine with stock internals just get a good tune and make sure to read a lot of info so you know what your motor can take before stuff starts to break.
Old Jul 15, 2007 | 01:19 PM
Tippyman's Avatar
Default Re: (TehGhett0P1mp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TehGhett0P1mp &raquo;</TD></TR><TR><TD CLASS="quote">
HP people not PSI... One PSI on a turbo is completely different on another one...</TD></TR></TABLE>
Thank you.
Before you even start looking at going turbo, you have to figure out how much power you want.
Let's say you wanna make 250 horsepower. Then you buy the components you need to make the engine withstand that power. Then you buy the properly sized turbo and all the tons of **** that you need to go with it.
Old Jul 15, 2007 | 05:18 PM
ghostcivic's Avatar
o well i dont know how much im puting to my wheels.i think i was told that my motor has 147 stock but that in a teg and i dont have ps or ac on my motor.i would like to hit over 200 hp but i will be happy with something close to that.i would like to find out how much whp i have in my civic but i cant find a dino anywhere close to here.so to get it up to 200 i just dont know where to start.i have my other car(97 civic all stock) so pulling my motor is not a problem.i just lack the know how. any help? thanks
Old Jul 16, 2007 | 09:07 PM
ghostcivic's Avatar
bump for more info........
Old Jul 16, 2007 | 09:22 PM
DecentCivicZ6's Avatar
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostcivic &raquo;</TD></TR><TR><TD CLASS="quote">o well i dont know how much im puting to my wheels.i think i was told that my motor has 147 stock but that in a teg and i dont have ps or ac on my motor.i would like to hit over 200 hp but i will be happy with something close to that.i would like to find out how much whp i have in my civic but i cant find a dino anywhere close to here.so to get it up to 200 i just dont know where to start.i have my other car(97 civic all stock) so pulling my motor is not a problem.i just lack the know how. any help? thanks </TD></TR></TABLE>
if all you want is 200hp. low boost will get you that EASY with a tune. or just spray it. but b18b is like 140crank hp, so thats around 111whp-125whp. Seen a dyno on the B18a1 which is 130hp factory, put down 111whp stock.
Old Jul 18, 2007 | 07:05 PM
ghostcivic's Avatar
Default Re: im thinking turbo! (DecentCivicZ6)
now im going to need like hondata or something right?do u know how much the dealer charges to but the chip in the ecu?and does every dealer do it? and whats the best one for the price? thanks guys
Old Jul 18, 2007 | 08:04 PM
Schister66's Avatar
Man U FTW
no dealer is going to chip an ECU for you...
check out http://www.j-k-tuning.com
Old Jul 18, 2007 | 08:37 PM
B A N N E D
or check this guy out..which ever is closer..he does all mine and my friends..cool dude
http://mysite.verizon.net/mccecuservice/
Old Jul 19, 2007 | 06:46 AM
ghostcivic's Avatar
****..... i just realized i dont have a obd1 i have an obd2 hondata wont work.do u guys think its better to go with something else.or get the obd1 conv. and get the hondata.if i should get a different one what good thats out there for the price? thanks yall
Old Jul 19, 2007 | 07:24 AM
ghostcivic's Avatar
if i do the conv.from the obd2 to the obd1 what with change(if anything)with the way it works with the motor? anybody got a p75 chiped?what did u go with? thanks everybody
Old Jul 19, 2007 | 03:23 PM
ghostcivic's Avatar
bump for more info
Devanw5725
Jun 15, 2013 11:50 AM
w3aselll
May 20, 2010 05:28 PM
AZ90DATEG
Feb 27, 2007 04:18 AM
Doostur
Oct 3, 2004 09:52 PM
scooter
Jul 15, 2002 09:40 PM
