im putting turbo on my b16a I think?
Old Jan 26, 2005 | 07:33 AM
Boring's Avatar
Default im putting turbo on my b16a I think?
ok a stock 88-91 b16a is going into my 91 crx si from hmotorsonline.com
anyways my question is I have a garrett t3/t4 turbo w/manifold and intercooler. they say the motor has anywhere from 25k to 35k is it "safe" to slap on this turbo for low boost like 5psi?
Old Jan 26, 2005 | 07:34 AM
tgreaves's Avatar
Default Re: im putting turbo on my b16a I think? (wc300zx)
Do a compression test on the motor to check it out.. Mileage has nothing to do with the condition of the motor.. If tuned properly then everything will work fine..
Old Jan 26, 2005 | 07:58 AM
Boring's Avatar
Default Re: im putting turbo on my b16a I think? (tgreaves)
they said at hmotorsonline they compression test all they're engines, im pretty sure he sed 250psi or 255psi each cylinder?
correct me if im wrong.
Old Jan 26, 2005 | 07:59 AM
tgreaves's Avatar
Not sure what they do but I would still do one anyway.. You can pick them up really cheap.. What fuel/ignition management are you going to go with?
Old Jan 26, 2005 | 08:03 AM
Boring's Avatar
what ecu? sorry im kinda new to the honda seen I have a Zdyne but the motors coming with a stock ecu i'll probably have that put in.
Old Jan 26, 2005 | 09:05 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wc300zx &raquo;</TD></TR><TR><TD CLASS="quote">what ecu? sorry im kinda new to the honda seen I have a Zdyne but the motors coming with a stock ecu i'll probably have that put in.</TD></TR></TABLE>
Your zdyne should work fine on a boosted car, I havent messed with the zdyne though.. Just make sure you get it tuned..
Old Jan 26, 2005 | 09:12 AM
pnut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Do a compression test on the motor to check it out.. Mileage has nothing to do with the condition of the motor.. If tuned properly then everything will work fine..</TD></TR></TABLE>
mileage has everything to do with the condition of the motor... you're telling me if you "properly tune" a motor that has 300k on the internals, then it will be fine?...
Old Jan 26, 2005 | 09:17 AM
tgreaves's Avatar
Default Re: im putting turbo on my b16a I think? (pnut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnut &raquo;</TD></TR><TR><TD CLASS="quote">
mileage has everything to do with the condition of the motor... you're telling me if you "properly tune" a motor that has 300k on the internals, then it will be fine?... </TD></TR></TABLE>
Yep.. Even if it has a million miles on it, it would be fine to boost.. Do you have any information to prove me wrong?
I have seen an engine with 10k on it smoking and had broken ring lands in it.. I have also seen an engine with over 500k on it still running like the day it was bought..
Tchleung's Avatar
You are more likely to blown a UNTUNED low mileage engine, then a tuned high mileage engine. There are many ppl with high mileage and boost
Old Jan 26, 2005 | 09:18 AM
tgreaves's Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">You are more likely to blown a UNTUNED low mileage engine, then a tuned high mileage engine. There are many ppl with high mileage and boost</TD></TR></TABLE>
Yup.. I taked to a guy that other day that I tuned his car like a year ago and he just hit the 330k mark and hes boosted.. Runs high 13's in a crx with a stock motor..
Old Jan 26, 2005 | 11:54 AM
Boring's Avatar
Default Re: (tgreaves)
see the Zdyne I have worked fine but it seems like its been " acting up " lately. its throwing wrong codes etc. but i'll try it if it doesnt work i'll have to use the stock ecu .
Old Jan 26, 2005 | 12:02 PM
tgreaves's Avatar
Default Re: (wc300zx)
well your going to need to do more than just putting the stock ecu in there if you want to boost it..
And I see you live in west chester, pa.. Been near Bams house???
Old Jan 26, 2005 | 06:35 PM
Boring's Avatar
haha yea ive been there b4 I work at the skatepark bams cool but skating wise ehh.
Labelle19
Dec 21, 2009 02:25 AM
91civicsikid
Jul 16, 2008 02:49 AM
ccfab
Jan 28, 2006 11:38 AM
ninjaturtle1023
Jul 9, 2004 06:45 AM
Yosshaa
Aug 24, 2003 09:13 AM
