I'm finally boosted!
Old May 13, 2004 | 06:13 AM
  #26
SOHC_MShue's Avatar
Default Re: (boostincoupe)
yea i hope to god it works. Those of you that have had a leaky headgasket when was your temperature rising? Was it under boost or when you slow down after a boosting session like when you were going slow like me?
Old May 13, 2004 | 06:20 AM
  #27
ELSpool's Avatar
After boost. The air pockets in your coolant system cause your gauge to fluctuate as they get trapped. Your car in not actually over heating.
Old May 13, 2004 | 06:58 AM
  #28
DaX's Avatar
DaX
Loved
Community Favorite
While you're at it throw in a new thermostat...just for the comfort.
Old May 13, 2004 | 07:06 AM
  #29
slamedturtle's Avatar
Default Re: (SOHC_MShue)
congrats man, oh by the way..... welcome to the crazy *** world of boost. have fun.
Old May 13, 2004 | 07:54 AM
  #30
turbozc2001's Avatar
to get accurate reading water temp put aftermarket water gauge. the stock gauge not accurate.
Old May 13, 2004 | 08:47 AM
  #31
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">After boost. The air pockets in your coolant system cause your gauge to fluctuate as they get trapped. Your car in not actually over heating.</TD></TR></TABLE>
sweet. Me and SOHC_MShue have the same exact issue then (same car too). So a flush/refill with 50/50 mix, new OEM rad. cap and proper bleeding should do the trick?
Old May 13, 2004 | 08:53 AM
  #32
SOHC_MShue's Avatar
oh **** are you serious? Is it just air that got into my coolant system then? So I really don't have a blown headgasket? Is it just the air pushing my coolant out of the resivior?
Old May 13, 2004 | 09:11 AM
  #33
ELSpool's Avatar
ok, maybe I'm not explaining right. How do you think air gets into the system...? Boost, your head lifts, the cylinder pressure gets forced inbetween the head and deck, seperating the seal your HG had formed. Whats on the other side of the sleeves? Your coolant jackets, pressure gets in there, over pressurized the systems max psi, pushes coolant out your overflow, and now you have air pockets in the system causing your temp gauge to move up and down as they pass by the temp sensors.
Old May 13, 2004 | 09:13 AM
  #34
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool &raquo;</TD></TR><TR><TD CLASS="quote">ok, maybe I'm not explaining right. How do you think air gets into the system...? Boost, your head lifts, the cylinder pressure gets forced inbetween the head and deck, seperating the seal your HG had formed. Whats on the other side of the sleeves? Your coolant jackets, pressure gets in there, over pressurized the systems max psi, pushes coolant out your overflow, and now you have air pockets in the system causing your temp gauge to move up and down as they pass by the temp sensors.
GAY!
Old May 13, 2004 | 09:43 AM
  #35
SOHC_MShue's Avatar
yea thats what i was thinking ...****
Old May 16, 2004 | 08:41 PM
  #36
SOHC_MShue's Avatar
alright i blead the coolant system and drove around for a while...my car was still doing the fluctuating temp thing, but when I checked my overflowtank it wasn't full like before. Shouldn't my tank have had coolant being pushed into it again?
Old May 17, 2004 | 04:43 AM
  #37
SOHC_MShue's Avatar
bump
Old Aug 7, 2004 | 06:53 PM
  #38
VTgringo's Avatar
yeah, you can try all the little stuff but more than likely its the headgasket.....i've been down that road too many times now......budget boosting, i wouldn't suggest to anyone
Old Aug 7, 2004 | 08:11 PM
  #39
SOHC_MShue's Avatar
Default Re: (VTgringo)
Damn back from the dead . I fixed that while ago and updated my setup with a new fmic and some nice new charge pipes and arp headstuds. Too bad now I blew my second headgasket yesterday
JpiZz0
Oct 30, 2007 06:38 PM
sonicivic
Jul 9, 2007 03:23 PM
4inspeed
May 5, 2006 05:30 PM
wisjdmhonda
May 22, 2004 08:37 PM
VTC_CiViC
Sep 4, 2001 07:03 AM
