Question about crome.. very URGET!!!
Hello,
Ok, I have basemap on which my car starts and work fine in neutral.. I want to go to track with this for futher street tuning but I don't know how much ignition retard this map is using..
How can I check how much ignition retard is set in crome?
Please help!!!
Please help!!!
I don't recommend tuning your motor, or driving it, until you've learned a bit more. Sounds harsh but you're gonna blow the expletive up at that rate.
1) Setting a standard "ignition retard" amount is bullshit for "tuning", except as a starting point,
2) If you can't find the ignition tables on the map you posted, how are you gonna tune it?
But because I'm a super nice guy I installed Crome on my work computer and had a look. Open your .bin file and press F6, that will show you high cam timing. Then press F3 to see the map view, and F2 to compare the table view. Count the numbers yourself...
I will tell you it appears to have way too much timing for pump gas.
W O T
Aug 13, 2006 03:27 PM
