Ignition retard per pound of boost?
Old May 6, 2004 | 11:58 AM
b18psi's Avatar
Default Ignition retard per pound of boost?
I am running 8 pounds of boost on a b18c1 with a MSD Digital 6 Plus and Blaster SS coil. How much ignition retard should I be running?
Old May 6, 2004 | 12:02 PM
pornstarSR's Avatar
Default Re: Ignition retard per pound of boost? (b18psi)
i was told 1 degree per 2psi....
so for 8psi.... 4 degrees retard
Old May 6, 2004 | 02:57 PM
keebler65's Avatar
Default Re: Ignition retard per pound of boost? (pornstarSR)
you didnt say what octane gas you were using, however i run 6psi on 93 octane and i use .8 degrees per pound of boost to be on the safe side. you never know when you might get a bad tank of gas.
Old May 6, 2004 | 03:01 PM
primeredbeast's Avatar
Default Re: Ignition retard per pound of boost? (keebler65)
my buddy uses .5 degree per pound of boost
Old May 10, 2004 | 08:10 AM
b18psi's Avatar
The problem I am having is that at high rpm 6500 to 8000 rpm my car (integra gsr) is missing and the power cuts out dramatically and wont rev any higher. The wierd thing is that it started doing this when I installed my MSD Digital 6 plus. I already had a Blaster ss coil, MSD wires with ngk cold range plugs and MSD cap on the car and it was fine. I have sent the box back to MSD and they said it is fine. I run 93 octane gas and spark plug gap is .31. I have been troubleshooting the electrical system (ground kit, replaced the rotor, changed plugs), but now I am going to check the ignition timing. I am not exactly sure what I am at now. My car is also running rich, so I guess I am needing even more retard because rich mixtures burn faster. I am planning on going 1 degree per psi to start out with. One more question: Which direction do you turn the dist to retard the ignition? Also if anyone has any ideas about the missfire it would be appreciated? Thanks
Old May 10, 2004 | 03:57 PM
iiilgsrlll's Avatar
Default Re: (b18psi)
What are you using for fuel management?
I had the same problem you are experiencing when it was overly rich. I was about 20% rich to be exact.
Old May 11, 2004 | 04:15 AM
b18psi's Avatar
I am using a vortech fmu. My car has run rich since before the turbo. I have two check engine lights for the two O2 sensor heaters. This has made my ecu run in safe mode which is rich. I have an OBD1 ecu (my car is 96 - OBD2) on the way and it only uses one O2 sensor. I also have a SX fuel pressure regulator and STR fuel rail that I haven't installed yet. Once I get it on I can turn down the fuel pressure and maybe that would fix it.
Last night my friend brought over his timing gun and we hooked it up. When we pulled the trigger the strobe wasn't consistant, it would pulse five or so times the skip a few. He said it was a cheap gun. Another friend of mine has a snap-on gun so I will try to get a hold of it.
Old May 11, 2004 | 05:00 AM
BEV@GSCMotorsports's Avatar
I've got a similar question, but what is a good base timing... apx. 16* right?
Old May 11, 2004 | 10:05 AM
Old May 11, 2004 | 10:26 AM
iiilgsrlll's Avatar
Make sure you jump the diagnostics plug under the glove box otherwise the ECU will compensate for every change you make to the timing.
If you're boosting I would suggest that you not set it 16 degrees especially with no standalone. You'll need to retard the timing.
Old May 11, 2004 | 11:18 AM
gdrum's Avatar
Default Re: (iiilgsrlll)
im runnin .8 degrees for 6psi on my turbo setup...
Old May 11, 2004 | 11:43 AM
Default Re: (gdrum)
when i jump the plug under the dash, do i only do that while setting it, or do i leave it in at all times? Thanks for the tip...
For basetiming how much should i retard from 16*?
Old May 11, 2004 | 12:02 PM
pornstarSR's Avatar
Default Re: (CivicTurbo12)
it depends on how much your boosting..
and on what motor..
on my D our base stock timing is 12-14
b series are 14-16
i would say going past 8 degrees base timing would be too much... plus if you pushing enough boost to have to be more than 8 degrees retarded... then you need standalone..
Old May 11, 2004 | 12:10 PM
Default Re: (pornstarSR)
Well i'm running LS/Vtec, JE 9:1, Eagle Rods, block guard, PNP head, etc. @ 10-11 lbs. You think that apx 8* bastiming is the way to go... and appx .5* retarded per pound of boost... Thanks for the help
Old May 11, 2004 | 01:06 PM
pornstarSR's Avatar
8-10 degrees....
if .5 per psi is good..... every car is different....
start with 8.... if you want go to 10... and listen to the motor.. if it detonates go back to 8
s2kkid
Jan 25, 2006 08:17 AM
AJxr
Dec 14, 2005 08:20 PM
Bspec18
Jun 30, 2003 12:55 PM
5thgencivic
May 20, 2003 11:50 AM
LillDragun
Nov 7, 2002 12:19 AM
