Ignition problem. So spark. Msd system
Old Oct 17, 2010 | 01:01 PM
  #26
2k.civic.si's Avatar
Default Re: Ignition problem. So spark. Msd system
Originally Posted by jetspeedz
I take it you ran this setup with 1k resister between ecm and msd on white wire
Nope....i mean completely pull the ignitor out of the distributor...if you remove the ignitor completely you will suddenly find things like your stock tach dont work without some extra goodies.
Old Oct 17, 2010 | 01:03 PM
  #27
jetspeedz's Avatar
There is another option to bypass the ICM but it requires building a more robust ICM and runs external to the distributor. Ill see if i can dig up that circuit.
Old Oct 17, 2010 | 01:04 PM
  #28
im currently in the process of doing a bulk purchase of the parts needed and having pcb's made to build kits.
Old Oct 17, 2010 | 01:05 PM
  #29
jetspeedz's Avatar
this is courtesy of Matt, however you are still running an ICM so you are not bypassing it technically as with an M&W setup
Old Oct 17, 2010 | 01:07 PM
  #30
yup...thats the proper way to get rid of the factory icm
Old Oct 17, 2010 | 01:08 PM
  #31
jetspeedz's Avatar
Technically speaking you are still running an ICM so you can either take time and spend money to build this setup or do it right and get a M&W setup...
And lets make this clear the Circuit came from Matt (Dax) not you!
Old Oct 17, 2010 | 01:09 PM
  #32
never said the circut came from me... lol
  #33
jetspeedz's Avatar
For those interested in this option here is the original link. Matt is no longer making these so don't bother asking him to build you one...
https://honda-tech.com/forums/showth...1154593&page=2
Old Oct 17, 2010 | 01:12 PM
  #34
and dax wasnt the one who came up with the circut...J&S did years before he posted that.
Here is the original public posting by blundar
http://wikitest.pgmfi.org/twiki/bin/...torReplacement
Old Oct 17, 2010 | 01:17 PM
  #35
jetspeedz's Avatar
Fair enough lets give John credit.
Old Oct 17, 2010 | 01:19 PM
  #36
jetspeedz's Avatar
And to get back to this post, this setup will work just fine, the MSD tach output will drive the oem tach
http://filebox.vt.edu/users/poldim/h...%20Install.jpg
RaceCarRyne
Sep 2, 2007 11:32 AM
djtsmith007
Jun 23, 2007 08:31 AM
fafsa
Feb 23, 2005 07:39 AM
BoroDB8
Apr 18, 2002 03:26 PM
