ignition problem help!!!!!!
Old Jul 29, 2005 | 05:46 PM
mint's Avatar
Default ignition problem help!!!!!!
i have a msd 6A and a blaster coil and hondata with s200 it is cutting my spark at 7200 and my rev. limiter is set at 8000 why? It's not a rev limiter it's a cut. When it happens and i try to keep the pedal to the floor i just get nothing. It doesn't bounce like a normal rev limiter would do, it's like a big smack in the face. we went back over the whole system and tryed a new 6A and did the same thing. also hooked hondata up to the laptop and it said everything was ok
thanks for helping...
Old Jul 29, 2005 | 06:02 PM
N20civicB18's Avatar
Default Re: ignition problem help!!!!!! (mint)
you sure its not the factory rev limiter taking affect?
Old Jul 29, 2005 | 06:27 PM
Drag-Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mint &raquo;</TD></TR><TR><TD CLASS="quote"> It's not a rev limiter it's a cut. When it happens and i try to keep the pedal to the floor i just get nothing. It doesn't bounce like a normal rev limiter would do, it's like a big smack in the face. </TD></TR></TABLE>
Old Jul 30, 2005 | 06:11 AM
Default Re: ignition problem help!!!!!! (Drag-Accord)
(I'm attempting to help him with this problem)
This also came out of nowhere. Everything was working fine before, and after he changed his msd ignition is when this whole thing started. But we have tested it with a different msd box and it still does it. We have tried different plugs, different plug wires, pretty much everything we can think of to do.
Anyone ever had this problem before?
Old Jul 30, 2005 | 06:45 AM
vaporboy12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">you sure its not the factory rev limiter taking affect?</TD></TR></TABLE>
also check to make sure you got the cylinder selection wires cut
CiViC1990
Nov 19, 2007 06:32 PM
mike93eh2
May 31, 2007 08:13 PM
143MYVTECEF
Jan 30, 2006 12:41 PM
Agamemnon
Mar 4, 2002 07:35 PM
