idle problem
Old Jun 10, 2009 | 09:54 PM
teg_95's Avatar
Default idle problem
sorry i searched but i must be blind so im going to ask it. i just put my t3/t4 turbo kit on. and i am have idl problems. say im driving and i push the clutch in at a stop light then the car just dies. when i start it back up its fine just idles a little ruff. i know i need a tune and i checked the vacuum lines. and that checks out good. any idea.
Old Jun 10, 2009 | 10:26 PM
b3st0fth3w0rst's Avatar
Default Re: idle problem
what kind of injectors are you running? try increasing the IACV duty cycle if u can, had the same problem, but i used ectune to increase the IACV duty fixed the problem. also if you have large injectors, u'll need to get it tuned for it to run properly, meaning the batt offsets for your injectors.
Old Jun 11, 2009 | 04:56 AM
teg_95's Avatar
well i have the ecu chipped for the 440's that im using. but next tuesday it is going to get tuned. just wanted to try and get the small problems irond out.
teg_95's Avatar
also how do i increase the duty of the IACV
s032105k
Engine Management and Tuning
Apr 12, 2011 10:14 AM
s032105k
Apr 12, 2011 07:56 AM
Dan_the_MaN
Nov 18, 2005 01:42 AM
soopafly828
Mar 15, 2003 07:17 AM
