idle is missing??
Old Jan 26, 2007 | 11:50 AM
ilovejdmhoes23's Avatar
Default idle is missing??
i just boosted my car and its not tuned yet but when i start it up it idles at 1500 and also sounds like the car is miss fireing! it will idle smooth for a few seconds then misfire then smooth then again! its a gsr with a un chipped p28! thank you can some let me now whats wrong with it
Old Jan 26, 2007 | 12:04 PM
Default Re: idle is missing?? (ilovejdmhoes23)
any 1
Old Jan 26, 2007 | 12:13 PM
ham's Avatar
ham
are you running the stock injectors?
Old Jan 26, 2007 | 12:17 PM
Default Re: idle is missing?? (ham)
yea
Old Jan 26, 2007 | 12:21 PM
IntegraTypeR's Avatar
are you using stock plugs? and did adjust your dist timing?
Old Jan 26, 2007 | 12:34 PM
iBrandon's Avatar
Default Re: idle is missing?? (IntegraTypeR)
clean ur iacv and adjust ur idle screw accordingly...it should idle around 400-450 rpm with out dying, when the iacv is unplugged...then should idle at 800-850 rpm or so when its plugged back in..
Old Jan 26, 2007 | 01:45 PM
ham's Avatar
ham
you didnt go beating on it now that its boosted and untuned did you?
Old Jan 26, 2007 | 10:45 PM
bump
Old Jan 27, 2007 | 07:59 AM
ham's Avatar
ham
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">you didnt go beating on it now that its boosted and untuned did you?</TD></TR></TABLE>
Old Jan 27, 2007 | 08:21 AM
aaroboost's Avatar
uh oh...i have a hunch
Old Jan 27, 2007 | 08:39 AM
shauniewalnuts's Avatar
Default Re: idle is missing?? (aaroboost)
ummm maybe do a coil test, and an ICM test
its pretty easy to do you just need a multimeter
just search the ohms and test points on ht
Drkaccrd
Nov 25, 2006 03:46 AM
sLoWrAcEr
17
May 22, 2005 04:05 AM
drowzysleeper
May 18, 2005 01:40 PM
jerbear!
May 9, 2005 11:00 AM
6thgen4u2nv
11
Jan 11, 2004 03:19 PM
