1000CC injector idle
Old Nov 24, 2006 | 09:22 AM
Drkaccrd's Avatar
Default 1000CC injector idle
like the topic says how does the 1000cc injectors idle for ya? Or whats the lowest rpm youve ever got it to idle?
Old Nov 24, 2006 | 09:35 AM
BoostedEG6's Avatar
Default Re: 1000CC injector idle (Drkaccrd)
mine idle around 850-900 rpm
Old Nov 24, 2006 | 10:01 AM
Drkaccrd's Avatar
Default Re: 1000CC injector idle (BoostedEG6)
did you get your ems to make it idle like that or was it its natural idle?
JDMRice's Avatar
Idle like stock.
Old Nov 24, 2006 | 10:05 AM
komat's Avatar
Default Re: 1000CC injector idle (JDMRice)
idles at 900 with neptune 1.9lsvtec type r cams
Old Nov 24, 2006 | 10:31 AM
Drkaccrd's Avatar
Default Re: 1000CC injector idle (komat)
doesnt sound too bad. I guess once you go above 1000cc in the 1250-1600cc range the idle starts to get naturally high. Hows your gas mileage on the 1000cc?
Old Nov 24, 2006 | 10:33 AM
OBRJosh's Avatar
Mines just like stock with the S300 800rpm
Old Nov 24, 2006 | 11:08 AM
komat's Avatar
Default Re: 1000CC injector idle (OBRJosh)
if your car is tuned correctly your mpg should be the same
Old Nov 24, 2006 | 11:36 AM
Drkaccrd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBRJosh &raquo;</TD></TR><TR><TD CLASS="quote">Mines just like stock with the S300 800rpm </TD></TR></TABLE>
sounds pretty good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">if your car is tuned correctly your mpg should be the same</TD></TR></TABLE> whats your gas mileage?
Old Nov 24, 2006 | 11:37 AM
komat's Avatar
22-24mpg in city
30+ in hw
Old Nov 24, 2006 | 11:54 AM
ShawnR's Avatar
do u have an injector drive like the fjo or the aem one?
Old Nov 24, 2006 | 12:16 PM
Drkaccrd's Avatar
wow thats good. And your Hp & Tq is in your sig? How many lbs of boost & whats your set-up?
Old Nov 24, 2006 | 12:31 PM
OBRJosh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drkaccrd &raquo;</TD></TR><TR><TD CLASS="quote">wow thats good. And your Hp & Tq is in your sig? How many lbs of boost & whats your set-up?</TD></TR></TABLE>I run the Stock honda resitor box works great
Old Nov 24, 2006 | 12:37 PM
jrs2ksi's Avatar
i was thinking about running 1000cc injectors when i boost my civic. Should it idle the same as stock or do u have to tune it?
Old Nov 24, 2006 | 12:42 PM
morgan@synapse motorsport's Avatar
im running 1000cc injectors, and it idles at around 1000rpm, and i get around 35 hwy mpg on my 1.9 liter b series.
aem ems no driver box, just a honda resistor box
Old Nov 24, 2006 | 01:07 PM
ShawnR's Avatar
Default Re: (hybrdthry911)
u need peak and hold or saturated to run a honda resisor box?
Old Nov 24, 2006 | 01:16 PM
OBRJosh's Avatar
Default Re: (97gsrcoupe)
peak and hold,
Old Nov 24, 2006 | 01:17 PM
Chris22215's Avatar
peak and hold for the resistor box.
my 1000cc idle just like stock at 750rpm+- and i'm averaging 33-35 driving (with a little boost )
Old Nov 24, 2006 | 01:57 PM
Drkaccrd's Avatar
Default Re: (Chris22215)
so in order to idle normally you this [QUOTE=Chris22215]-peak and hold for the resistor box. - Or tuning would be the key?
Old Nov 24, 2006 | 03:12 PM
resistor box is required for the peak and hold injectors, they dont offer any 1000cc injectors that arent peak and hold, and yes the way it idles has a lot to do with the tune. ive heard injector drive boxes help
Old Nov 24, 2006 | 03:31 PM
akira712's Avatar
1000cc's here isle like stock, my only problem is when slowing down and i take it out of gear car always dies, unless the revs are down near 1500-1000
Old Nov 24, 2006 | 04:05 PM
komat's Avatar
Default Re: (eastcoast_ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastcoast_ej &raquo;</TD></TR><TR><TD CLASS="quote">1000cc's here isle like stock, my only problem is when slowing down and i take it out of gear car always dies, unless the revs are down near 1500-1000</TD></TR></TABLE>
that can be fixed easily with some tuning. in crome theres a section where you can set the idle when the car is moving
Old Nov 24, 2006 | 05:18 PM
oscarmayer's Avatar
i have 1000CCs on a single cam and idle perfectly.
Old Nov 24, 2006 | 05:36 PM
boosted1993's Avatar
Default Re: (oscarmayer)
Wow, I have rc750's that i just put in yesterday and have a new base map and my car idles very badly... any ideas why? do i need more fuel pressure? I 'm running stock fpr.
Old Nov 24, 2006 | 06:03 PM
N20civicB18's Avatar
Default Re: (boosted1993)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted1993 &raquo;</TD></TR><TR><TD CLASS="quote">Wow, I have rc750's that i just put in yesterday and have a new base map and my car idles very badly... any ideas why? do i need more fuel pressure? I 'm running stock fpr.</TD></TR></TABLE>
You are on a basemap, get it tuned!
my 1000's idled like stock except for a couple extra spudders every now and again but it idle'd like stock
