idea for mbc's
Old Mar 10, 2008 | 12:06 AM
projectstacy's Avatar
Default idea for mbc's
i have an idea i've been toying with for a three stage boost controller. I wanna run one setting at the wastegate pressure(8psi), one at 10 psi and the third at 15 psi. I'm cheap, poor, and love to do things my own way, so instead of buying an expensive dual or quadstage MBC, or a EBC, i decided to build my own MBCs. the concept is simple, but i'm not 100% sure if it'll work. here's a diagram. do you think it'll work?
also, what modifications need to be made to make this work? what am i missing?
Old Mar 10, 2008 | 12:55 AM
KENetics1's Avatar
Default Re: idea for mbc's (projectstacy)
is this for a honda? what ems?
Old Mar 10, 2008 | 09:42 AM
Default Re: idea for mbc's (KENetics1)
yeah this is for a honda..sorry for the lack of info..it was nearly 3am when i made this post...it's gonna be a b16a2 boosted with a garrett t3/t4 60 trim .63 ar...head is gonna have supertech valvetrain and gsr cams skunk2 cam gears..block is stock sleeved at stock bore..eagle rods, cp pistons, acl bearing set, and arp hardware holding it together...3 inch downpipe..with a thermal 3 inch exhaust...tunned on neptune rtp...all going in my DA...
Modified by projectstacy at 11:04 AM 3/10/2008
Modified by projectstacy at 11:23 AM 3/10/2008
Old Mar 10, 2008 | 10:02 AM
jfoster's Avatar
I say try it out. I was planning to try something like this for a 2 stage set up. I didn't think of the purge control sol though. I was planning to use a fuel tank switch from a '93 F150 to change the vac routing to with / without MBC.
Old Mar 10, 2008 | 10:08 AM
Default Re: idea for mbc's (jfoster)
i wanna see if this will work before i put it on..this is my first tubo build that i complete 100%..i started one some time back..but decided boosting wasn't right for me then..so in all reality..this is my first turbo build ..everything is gonna be done by me, except the tunning...i just want someone more experienced in boosting to let me know if this set up works..i would hate to mess anything up...and yes..i searched...
Old Mar 10, 2008 | 10:18 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectstacy &raquo;</TD></TR><TR><TD CLASS="quote">tunned on hondata s300</TD></TR></TABLE>
Do yourself a huge favor and cut all that craziness out and just put a simple boost solenoid on there and control it through hondata.
EDIT: The solenoid is like $40 (I think that's what I paid for it at the dealership). So unless you can get the 3 mbc's, the 3 purge solenoids, and all the wiring for $40, then this is cheaper too for you.
Old Mar 10, 2008 | 10:22 AM
.nate's Avatar
Dunc is right Hondata, Neptune, and eCtune all provide EBC functionality that you should make use of.
EDIT: Also to answer your original quesiton, I have seen the purge solenoid used successfully in this fashion before.
Old Mar 10, 2008 | 10:23 AM
Default Re: idea for mbc's (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT: The solenoid is like $40 (I think that's what I paid for it at the dealership). So unless you can get the 3 mbc's for $13 a piece, then this is cheaper too for you.</TD></TR></TABLE>
making this will cost ledd than $40..and i'm not using hondata..i'm tunning on neptune..my bad...
Old Mar 10, 2008 | 10:25 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectstacy &raquo;</TD></TR><TR><TD CLASS="quote">making this will cost ledd than $40..and i'm not using hondata..i'm tunning on neptune..my bad...</TD></TR></TABLE>
Ok, it's your call but the one EBC solenoid is going to be much better of a setup in terms of controlibility.
Old Mar 10, 2008 | 02:13 PM
ryan89crx's Avatar
http://www.homemadeturbo.com/f...418.0
Old Mar 10, 2008 | 03:41 PM
Default Re: (ryan89crx)
awsome..that's almost exactly like mine..except mine doesn't have diodes...so this should work then,right?
Old Mar 10, 2008 | 09:33 PM
bump
Old Mar 10, 2008 | 11:39 PM
KENetics1's Avatar
I too say go with a ebc solenoid, since when was $40 expensive? $40 or new engine due to boost spike?
EF ridin 4 Life
Jun 20, 2011 06:11 AM
spoolin turbo s
Mar 26, 2009 06:24 PM
hondabadtoy
Apr 18, 2008 05:07 PM
oMek
Feb 2, 2004 09:25 PM
1.8T_EG
Feb 5, 2003 12:52 PM
